[swak4Foam] installing funkySetFields
Old   July 5, 2011, 11:20
Assistant Moderator
Bernhard Gschaider
Originally Posted by vetnav View Post
Hi Bernhard,
Thank you for the reply. Thatis so prompt.
Is that directory opt/openfoam171/applications/utilities/preProcessing/ under SVN control like ther output suggests?
I don't even know what is SVN control, when I run make install I think it automatically going under that control. To make sure I restarted the computer and tried it but still got the same error message.
Which version did you download and how?
If your question is regarding the swak4Foam. I downloaded it using the command given in
http://openfoamwiki.net/index.php/Co...am#Downloading
I have only one user account in my Ubuntu.
Thank you
Sorry for the late answer.
If you downloaded it with the SVN-command then it is under SVN control and I realized that this breaks the inclusion of SFO via SVN. I added a external reference to that lib in the svn tree (don't worry what that means). Try "svn update" iin the swak-Sources. This should pull the simpleFunctionObjects into the source tree and everything should be fine. If that doesn't work try downloading the swak-Stuff completely anew with the command you used originally
Bernhard
Old   July 5, 2011, 11:35
Naveen
vetnav is on a distinguished road
Hi Bernhard,
I uninstalled Ubuntu from my computer and installed fedora. I installed the OpenFOAM source pack. Swak4foam also installed without many troubles.
Thank you
vetnav is offline   Reply With Quote
Old   October 2, 2015, 07:22
Default Error during installation of FunkySetFields
  #63
as
anuja is on a distinguished road
I am facing lot of error for the intsallation of funkysetfields. For now the error looks like below:
 This script is rather crude. If it doesn't work try the steps by hand. And be sure to run it from the root of the swak-inst         allation (as ./maintainanceScripts/compileRequirements.sh). Otherwise it probably won't work
bison-2.7.1.tar.gz already downloaded
Untarring bison-sources
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether make supports nested variables... (cached) yes
checking for style of include used by make... GNU
checking for gcc... no
checking for cc... no
checking for cl.exe... no
configure: error: in `/opt/OpenFOAM/OpenFOAM-1.6/openfoam-extend-Breeder1.7-libraries-swak4Foam-master/privateRequirements/         compilation/bison-2.7.1':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details
There seems to be no Makefile in this directory.
You must run ./configure before running 'make'.
GNUmakefile:106: die Regel für Ziel „abort-due-to-no-makefile“ scheiterte
make: *** [abort-due-to-no-makefile] Fehler 1
Bison not compiled. Check output
Add /opt/OpenFOAM/OpenFOAM-1.6/openfoam-extend-Breeder1.7-libraries-swak4Foam-master/privateRequirements/bin to PATH-variab         le. The ./Allwmake-script will use this directory automatically
Can someone please help me..
Regards,
Anuja
Last edited by wyldckat; October 3, 2015 at 12:18. Reason: Added [CODE][/CODE] markers
anuja is offline   Reply With Quote
Old   October 3, 2015, 12:19
Retired Super Moderator
Bruno Santos
Quick questions:
  1. Which Linux Distribution are you using?
  2. What installation instructions for OpenFOAM 1.6 did you follow?
  3. Why are you trying to use OpenFOAM 1.6?
Old   October 6, 2015, 03:50
as
I have installed openfoam on windows 7. I am using it for my master thesis work. I am taking help from the openwiki site for the installation.
Old   October 8, 2015, 17:46
Bruno Santos
Sorry, but that doesn't answer my questions, therefore I'm not able to help .
funkysetfields, installation, valueexpressionparser, wmake
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
Install OF 1.6.ext on Arch based distribution miro2000 OpenFOAM Installation 4 October 9, 2013 14:39
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
[swak4Foam] installing funkySetFields utility for OpenFOAM 1.4.1 ozie OpenFOAM Community Contributions 8 September 8, 2011 11:16
