Problem running tutorial
Old   November 27, 2012, 06:23
Default Problem running tutorial
Vincent Rolin
vrolin is on a distinguished road
I've seen this posted elsewhere, but the solutions don't seem to apply to my case.
I'm running OpenFOAM on Ubuntu in VirtualBox. I followed the instructions to install the Ubuntu Deb pack from the OpenFOAM website: http://www.openfoam.org/download/ubuntu.php
When I run icoFoam -help, I get the usage message as expected.
However I run the tutorial using the sequence
blockMesh
icoFoam
paraFoam
blockMesh and icoFoam run without error,
but paraFoam generates the error message:
OpenGL Warning: No pincher, please call crStateSetCurrentPointers() in your SPU
paraview opens and displays a grey 3D block.
Thanks so much for your help
vrolin is offline   Reply With Quote
Old   November 27, 2012, 06:42
treima is on a distinguished road
have you changed the settings in Paraview, that it displays the solution? From SolidColor to one of your variables?
regards
treima
treima is offline   Reply With Quote
Old   November 27, 2012, 06:49
Default Hi Treima
Vincent Rolin
I haven't changed any of the settings in Paraview,
I'm new to all of the software I'm using here and wouldn't have the first clue how.
Old   November 27, 2012, 07:36
Play a little bit around with the parameters in Paraview or do some online research, I think that will help you a lot.
For your special case, have a look at the description of the tutorial: http://www.openfoam.org/docs/user/cavity.php#x5-40002.1
regards
treima
Old   November 27, 2012, 10:21
Vincent Rolin
Thanks again,
This helped me understand how to view results in Paraview, but when I try to look at a variable like pressure, I still only see a blank surface.
I noticed while looking at the output of icoFoam, I see a time step continuity error at several iterations.
Old   November 27, 2012, 17:19
Retired Super Moderator
Bruno Santos
Greetings to all!
I'm too tired right now to go through my blog post Related issues to ParaView with OpenFOAM - Fixes and solutions
Check the links provided there and do let us know if one of them is of any help!
Good luck!
Bruno
Old   November 30, 2012, 08:12
Fergus
Jaggy_Snake is on a distinguished road
Is 3D acceleration turned on in your VB? I think I was getting a similar error until I disabled it... Could be wrong though
Jaggy_Snake is offline   Reply With Quote
opengl, parafoam, tutorial
Problem while running in Highperformance computing environment Phanipavan STAR-CD 1 September 11, 2013 06:42
Vessel tutorial problem hosseinhgf CFX 1 March 17, 2013 11:39
Problem in running ansys fluent13 mamadou zein FLUENT 0 February 13, 2012 03:17
problem with running in parallel dhruv OpenFOAM 3 November 25, 2011 05:06
DNS Foam tutorial problem msekandi1 OpenFOAM Running, Solving & CFD 5 June 23, 2006 13:27
