[OpenFOAM.org] OpenFoam 2.3.0 for Windows - error while loading shared libraries: libgcc_s_seh-1.dll
Like Tree1Likes
  • 1 Post By manuelffonseca
Old   August 14, 2014, 00:13
Default OpenFoam 2.3.0 for Windows - error while loading shared libraries: libgcc_s_seh-1.dll
Sachin
Sachin m is on a distinguished road
Hi Foamers,
Iam new to Open Foam. I have installed OpenFoam 2.3.0 for windows in my PC.
When i run the terminal and try to run: 'icoFoam -help' , it shows:
"error while loading shared libraries: libgcc_s_seh-1.dll: cannot open shared object file: No such file or directory"
Can any one tell me what could be the possible reason.
With regards
Sachin M
Sachin m is offline   Reply With Quote
Old   August 14, 2014, 01:06
Lianhua Zhu
zhulianhua is on a distinguished road
Hi, Sachin!
I have never played with OpenFOAM on Windows, but from your post, it seems you haven't installed or configured your windows version OpenFOAM properly.
BTW, I think it's more like to get you problem solved if you post in the OpenFOAM/installation sub-fourm here
openfoam-installation-windows-mac
Good Luck!
Lianhua
Originally Posted by Sachin m View Post
Hi Foamers,
With regards
Sachin M
zhulianhua is offline   Reply With Quote
Old   August 14, 2014, 06:46
Retired Super Moderator
Bruno Santos
Greetings to all!
I've moved these two posts to a new thread in the correct sub-forum (OpenFOAM Installation on Windows, Mac and other Unsupported Platforms as Lianhua indicated).
@Sachin: You will have to be more specific about which installation instructions you've followed.
Best regards,
Bruno
Old   October 13, 2014, 13:09
Xinping Zhou
Markzhou is on a distinguished road
Hi, Sachin,
Have you solved this problem? I got the same problem as yours.
Kind regards,
Zhou
Hi Foamers,
With regards
Sachin M
Markzhou is offline   Reply With Quote
Old   November 28, 2014, 20:32
Default Solved
Manuel Fermin Fonseca
manuelffonseca is on a distinguished road
Hi Sachin,
i had the same problem, but i solved it, its because we have to select te following packages;
1)mingw64-x86_64-gcc-g++
2)mingw64-x86_64-zlib
3)mc
those packages we can find in the windows that appears when we areinstalling Cygwin, only we can lo copy and paste on the frame and search and select those one by one...
Hi Foamers,
With regards
Sachin M
wyldckat likes this.
manuelffonseca is offline   Reply With Quote
error while loading shared libraries: libXm.so.3 Renato Pacheco FLUENT 3 July 3, 2008 12:48
gambit "error while loading shared libraries" ggrant FLUENT 1 June 25, 2008 10:37
FoamXHostBrowser error while loading shared libraries libFoamXso cannot restore segment prot after reloc Permission denied mdmk OpenFOAM Pre-Processing 0 June 25, 2008 00:50
error while loading shared libraries: libXm.so.3 Emiliano FLUENT 1 September 5, 2007 20:03
Error while loading shared libraries libstdcso6 maka OpenFOAM Installation 2 August 11, 2006 04:24
