[OpenFOAM.org] OpenFOAM compilation error
Like Tree1Likes
  • 1 Post By MarcoC
Old   April 23, 2015, 06:58
Default OpenFOAM compilation error
Marco Conte
MarcoC is on a distinguished road
I am trying to compile OpenFOAM 2.3.1 and my OS is OpenSUSE 13.2, I have run foamSystemCheck and all seems OK, but when I run Allwmake several errors occour. Errors looks like :
collect2: error: ld returned 1 exit status
/opt/OpenFOAM/OpenFOAM-2.3.1/wmake/Makefile:149: recipe for target '/opt/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/checkMesh' failed
make: *** [/opt/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/bin/checkMesh] Error 1
Ho can fix this ?
MarcoC is offline   Reply With Quote
Old   April 23, 2015, 16:00
Retired Super Moderator
Bruno Santos
Greetings Marco and welcome to the forum!
I strongly advise you to first build OpenFOAM as a normal user and not as root. Nonetheless, I'm guessing something didn't go very well when you started working in root mode, so I suggest you read/study this page: http://openfoamwiki.net/index.php/In...with_the_Shell
Beyond this, detailed instructions for building OpenFOAM 2.3.1 on openSUSE 13.2 are available here: http://openfoamwiki.net/index.php/In...#openSUSE_13.2
Best regards,
Bruno
Old   April 24, 2015, 12:37
Marco Conte
Best regards,
Bruno
problem solved following steps in http://openfoamwiki.net/index.php/In...#openSUSE_13.2
Regards,
Marco
wyldckat likes this.
Compilation Error vizvaz Fluent UDF and Scheme Programming 2 January 6, 2017 04:19
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
