[OpenFOAM.org] Trouble installing OF240 in Mint 17.1 Rebecca
Old   September 14, 2015, 10:43
Default Trouble installing OF240 in Mint 17.1 Rebecca
Fernando Soares Alves
FernandoSoares is on a distinguished road
Hello Foamers,
I'm trying to install the latest OpenFOAM release (currently 2.4.0) in Linux Mint 17.1 Rebecca according to the Deb Pack installation tutorial here. However it is not working for me right now. I've already done it before in another machine (same OS) and it worked fine.
According to the tutorial the first step is
VERS=$(lsb_release -cs)
which simply stores 'rebecca' in the $VERS variable (right?). The following step is
sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu $VERS main > /etc/apt/sources.list.d/openfoam.list"
As soon as I "sudo apt-get update" I get the error messages
Err http://www.openfoam.org rebecca/main amd64 Packages
  404  Not Found
Err http://www.openfoam.org rebecca/main i386 Packages
  404  Not Found
and by the end of it
W: Failed to fetch http://www.openfoam.org/download/ubuntu/dists/rebecca/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://www.openfoam.org/download/ubuntu/dists/rebecca/main/binary-i386/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
When finally trying to install it the package obviously can't be found
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package openfoam240
What am I doing wrong here? It probably is some silliness but I would pretty much appreciate any help in advance. Has anyone recently had a similar issue installing OF240?
Once again, thank you for your advise
F. Soares
FernandoSoares is offline   Reply With Quote
Old   September 14, 2015, 14:22
As I thought it was pretty simple to solve. Apparently rebecca does not work, but using trusty or even vivid (for 17.2 I believe) for the version of the distribution (VERS=trusty/vivid) does the trick. OF240 installed.
Old   October 4, 2015, 16:04
scruffyjoe
scruffyjoe is on a distinguished road
What exactly did you do to get it working? I'm having the same errors.
scruffyjoe is offline   Reply With Quote
Old   October 4, 2015, 16:08
Retired Super Moderator
Bruno Santos
Quick answer:
  • For Mint 17.1:
    sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu trusty main > /etc/apt/sources.list.d/openfoam.list"
  • For Mint 17.2:
    sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu vivid main > /etc/apt/sources.list.d/openfoam.list"
But before that, you better first run this command:
sudo add-apt-repository -r http://www.openfoam.org/download/ubuntu
Old   October 4, 2015, 16:38
Originally Posted by wyldckat View Post
Quick answer:
  • For Mint 17.1:
  • For Mint 17.2:
Yeah. I also set explicitly the version and as I am currently using 17.1 I used 'trusty', just as wyldckat replied. I don't actually why but 'rebecca' (lsb_release -cs 's output) doesn't really work. I hope it helps.
Best regards
Old   October 5, 2015, 01:47
scruffyjoe
Thanks a million Guys! Got it working with your help
[OpenFOAM.org] I have trouble installing openfoam 5.0 on ubuntu 16.04 haydii OpenFOAM Installation 5 December 27, 2018 10:56
[General] Trouble installing ParaView from source Jack_Landis ParaView 3 June 20, 2016 11:18
[OpenFOAM] Trouble installing ParaView from source Jack_Landis ParaView 4 June 15, 2016 10:32
[OpenFOAM.org] Installing OpenFOAM 2.3.1 on Mint 17 - ThirdParty stuff not seeming to compile MikeHersee OpenFOAM Installation 2 January 4, 2015 05:32
Trouble installing OpenFoam 2.10 on Ubuntu 11.10 LucasCG OpenFOAM Installation 17 January 27, 2013 14:58
