[OpenFOAM.org] Unable to determine IP address from host name "downloads.sourceforge.net" |
October 17, 2015, 12:24 |
Jamal Foroozesh
Rep Power: 13 |
Hi dear friend
During download OpenFoam 2.4 on Ubuntu 15.04 I get this error: ERROR The requested URL could not be retrieved The following error was encountered while trying to retrieve the URL: http://downloads.sourceforge.net/pro...0-1_amd64.deb? Unable to determine IP address from host name downloads.sourceforge.netThe DNS server returned: Server Failure: The name server was unable to process this query.This means that the cache was not able to resolve the hostname presented in the URL. Check if the address is correct. Your cache administrator is webmaster. Also during installation using terminal I get this error: Err http://www.openfoam.org/download/ubuntu/ vivid/main openfoam240 amd64 0-1 503 Service Unavailable E: Failed to fetch http://www.openfoam.org/download/ubu..._0-1_amd64.deb 503 Service Unavailable E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? What do I do? |
October 17, 2015, 12:57 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: It looks like either you're unable to access the website downloads.sourceforge.net or your internet connection broke when you were trying to download.
Try: Code:
ping downloads.sourceforge.net It should tell you something like this: Code:
PING downloads.sourceforge.net (216.34.181.59) 56(84) bytes of data. 64 bytes from downloads.sourceforge.net (216.34.181.59): icmp_req=1 ttl=242 time=138 ms |
October 17, 2015, 23:17 |
Jamal Foroozesh
Rep Power: 13 |
Thank you so much
It works fine. |
October 18, 2015, 05:16 |
new problem
Jamal Foroozesh
Rep Power: 13 |
I have another problem now:
I run openfoam correctly but when I write paraFoam code I get this error: FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers ./Allwclean ./Allwmake I install openfoam and paraview using this link: https://openfoamwiki.net/index.php/I...M-2.4.x/Ubuntu |
October 18, 2015, 06:41 |
Bruno Santos
Rep Power: 128 |
Quick answer: Please run the following commands:
cd $WM_THIRD_PARTY_DIR gzip < log.makePV > log.makePV.gz pwd |
October 18, 2015, 06:51 |
#6 | |
Jamal Foroozesh
Rep Power: 13 |
Basic problem: I cant go to path " $WM_THIRD_PARTY_DIR" When I write first command any thing not change |
October 18, 2015, 06:56 |
#7 | |
Jamal Foroozesh
Rep Power: 13 |
I find log.makepv |
October 18, 2015, 07:12 |
Bruno Santos
Rep Power: 128 |
Something went wrong when you were following the installation instructions. This command:
cd $WM_THIRD_PARTY_DIR Code:
echo $WM_THIRD_PARTY_DIR Check if the folder exists, by running the following command: Code:
ls -l ~/OpenFOAM/ThirdParty-2.4.x |
#9 |
Jamal Foroozesh
Rep Power: 13 |
other file:
October 18, 2015, 07:18 |
#10 | |
Jamal Foroozesh
Rep Power: 13 |
October 18, 2015, 07:23 |
#11 |
Jamal Foroozesh
Rep Power: 13 |
October 18, 2015, 07:43 |
#13 |
Jamal Foroozesh
Rep Power: 13 |
Here is log.makePV.gz
October 18, 2015, 08:41 |
#14 |
Bruno Santos
Rep Power: 128 |
No, something went wrong again.
Run the following commands: Code:
source $HOME/OpenFOAM/OpenFOAM-2.4.x/etc/bashrc echo $FOAM_INST_DIR echo $WM_PROJECT_DIR echo $WM_OPTIONS echo $WM_THIRD_PARTY_DIR Last edited by wyldckat; October 18, 2015 at 08:43. Reason: fixed typo |
October 18, 2015, 08:53 |
#15 | |
Jamal Foroozesh
Rep Power: 13 |
Here you are: |
October 18, 2015, 09:01 |
#16 |
Bruno Santos
Rep Power: 128 |
Now it's working properly? This is very strange... OK, run the following commands:
source $HOME/OpenFOAM/OpenFOAM-2.4.x/etc/bashrc cd $WM_THIRD_PARTY_DIR export QT_SELECT=qt4 ./makeParaView4 -python -mpi -python-lib /usr/lib/x86_64-linux-gnu/libpython2.7.so.1.0 > log.makePV 2>&1 gzip < log.makePV > log.makePV_New.gz |
October 18, 2015, 09:07 |
#17 | ||
Jamal Foroozesh
Rep Power: 13 |
October 18, 2015, 10:11 |
#18 |
Bruno Santos
Rep Power: 128 |
OK, now we are getting somewhere. You need to do again the first 3 steps for installing the packages that are needed: https://openfoamwiki.net/index.php/I...u#Ubuntu_15.04
October 20, 2015, 16:52 |
#19 | |
Jamal Foroozesh
Rep Power: 13 |
I forced to reinstall ubuntu and then install OpenFoam from source code. It works fine, now Thank you so much Jamal |
Unable to find the master host : at least one required | raunakjung | CFX | 2 | June 1, 2017 07:51 |
Fluent Parallelization Problem After AC Power Dropped | pawl | Hardware | 5 | November 13, 2016 06:08 |
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 | sam.ho | OpenFOAM Installation | 35 | April 5, 2014 15:31 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
