[mesh manipulation] createPatch seg-faults when trying on rotationally periodic faces (v2.0.x)
Old   March 6, 2012, 19:32
Default createPatch seg-faults when trying on rotationally periodic faces (v2.0.x)
Vishal Achasrya
vishalsacharya is on a distinguished road
Im having a problem with my createPatch...
So my boundary file has two faces that are rotationally periodic.. as in if rotate one about the z-axis, you get to the other, since it is a cylindrical geometry...
the patches from the boundary file are...
new_periodic_inlet_1_shadow
type patch;
nFaces 1392;
startFace 2565657;
periodic_inlet_1
type patch;
nFaces 1392;
startFace 2567049;
if you notice, the startFaces are different and the number of faces are the same for both... since i ensured that both faces have the same mesh... now, the following is from my createPatchDict file....
pointSync false;
patches
name periodic_inlet;
patchInfo
type cyclic;
neighbourPatch periodic_inlet_shadow;
transform rotational;
rotationAxis (0 0 1);
rotationCentre (0 0 0);
constructFrom patches;
patches (periodic_inlet_1 new_periodic_inlet_1_shadow);
name periodic_inlet_shadow;
patchInfo
type cyclic;
neighbourPatch periodic_inlet;
Now, notice that i set pointSync to false since both my faces have the same mesh....
Also, since im using version 2.0.x, i have to create both patches (the main and the cylic one) separately as two new patches... and use the original patches from my boundary file for constructing them... so i use the neighbourPatch keyword for this...
Also since i have rotational periodicity, i use the transform keyword and mention origin and axis...
Now when i run this, i get the following...
Any ideas or thoughts would be appreciated?
Create time
Reading createPatchDict.
Create polyMesh for time = 0
Adding new patch periodic_inlet as patch 18 from
type cyclic;
rotationAxis ( 0 0 1 );
rotationCentre ( 0 0 0 );
Adding new patch periodic_inlet_shadow as patch 19 from
type cyclic;
Moving faces from patch new_periodic_inlet_1_shadow to patch 18
Moving faces from patch periodic_inlet_1 to patch 18
Moving faces from patch new_periodic_inlet_1_shadow to patch 19
Moving faces from patch periodic_inlet_1 to patch 19
Doing topology modification to order faces.
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/vishalsa/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/home/vishalsa/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam::cyclicPolyPatch::getCentresAndAnchors(Foam:: PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::Field<Foam::Vector<double> >&, Foam::Field<Foam::Vector<double> >&, Foam::Field<Foam::Vector<double> >&, Foam::Field<double>&) const in "/home/vishalsa/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::cyclicPolyPatch:rder(Foam::PstreamBuffers&, Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, Foam::List<int>&, Foam::List<int>&) const in "/home/vishalsa/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5 Foam:olyTopoChange::reorderCoupledFaces(bool, Foam:olyBoundaryMesh const&, Foam::List<int> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&) in "/home/vishalsa/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
#6 Foam:olyTopoChange::compactAndReorder(Foam:oly Mesh const&, bool, bool, bool, int&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam::Map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::Map<int> >&) in "/home/vishalsa/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
#7 FoamlyTopoChange::changeMesh(FoamlyMesh&, bool, bool, bool, bool) in "/home/vishalsa/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/lib/libdynamicMesh.so"
in "/home/vishalsa/OpenFOAM/OpenFOAM-2.0.x/platforms/linux64GccDPOpt/bin/createPatch"
#9 __libc_start_main in "/lib/libc.so.6"
Segmentation fault
vishalsacharya is offline   Reply With Quote
createpatch, cyclic boundaries, openfoam 2.0.x
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 07:48
[snappyHexMesh] SHM is not extruding/adding Layers everywhere matthiasd OpenFOAM Meshing & Mesh Conversion 2 October 16, 2016 16:45
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
