Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] problem with ParaView 3.8
Old   July 10, 2010, 17:42
Default problem with ParaView 3.8
Chrisi1984 is on a distinguished road
I switched from OF 1.6 to OF 1.7!
I have got the problem that i can not watch my old results of OF 1.6 with the new paraView version 3.8!
Can anyone help me what I can do to solve this problem. I do not get any error message, but I can not see anything.
I tried to post process a tutorial case of OF 1.7 with ParaView 3.8 and it run without a problem. So the reason must be inside the files of the old OF 1.6 version.
Thanks in advance!!
Best regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   July 11, 2010, 03:33
Philippose Rajan
philippose will become famous soon enough
Hello there,
A Good Morning to you!
Just a quick question.... are you using "paraFoam" to post-process OpenFOAM cases using the reader plug-in available within the OpenFOAM distribution, or are you using the OpenFOAM reader which is already present as part of ParaView-3.8 ?
Philippose
philippose is offline   Reply With Quote
Old   July 12, 2010, 02:11
I am using paraFoam for post-processing.
Regards
Chrisi
Old   July 13, 2010, 02:39
I found a solution.
One has to rebuilt the mesh with OF 1.7. Than post-processing can be done with the new verson OF 1.7.
Regards Chris
Old   July 14, 2010, 17:07
now I can not even post-process simulations in paraFoam 3.8, which were calculated with OpenFoam 1.7.
Can anyone help me please?
Regards
Chrisi
Old   July 14, 2010, 18:02
Retired Super Moderator
Bruno Santos
Greetings Chrisi,
My bet is on you using a non English Ubuntu. I've posted today a solution (actually it's a recycled solution ), if that is the case: http://www.cfd-online.com/Forums/ope...tml#post267265
If that isn't the case, we are going to need some more information to go on! Like, what version and architecture of Ubuntu are you using; how did you install OpenFOAM, i.e., what instructions did you follow... and so on.
Best regards,
Bruno
Old   July 15, 2010, 06:47
Thank you!!
That was the also my problem.
Regards Chrisi
Problem with loading in paraview on hpc cluster reconstructedCase Lorenzo92 OpenFOAM Post-Processing 0 November 25, 2016 03:00
[OpenFOAM] Paraview 3.12 memory allocation problem while saving animation jgomez ParaView 17 September 14, 2013 17:03
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 aero_ ParaView 14 August 2, 2010 18:13
Yet another Paraview problem gascortado OpenFOAM 5 February 21, 2010 06:39
[OpenFOAM] Problem with Colors in ParaView sven ParaView 1 May 31, 2009 08:13
