oscillating cylinder dynamic mesh
Like Tree29Likes
Old   June 16, 2014, 08:54
Scabbard is on a distinguished road
Originally Posted by Maimouna View Post
Hi Scabbard,
of course, I need your help. I'm struggling on that for long time. If you don't mind please we can shear your idea and I would be really grateful.
My email address is: may78may@hotmail.com
Best regards
Maimouna
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      dynamicMeshDict;
dynamicFvMesh      dynamicMotionSolverFvMesh;
motionSolverLibs ("libsixDoFRigidBodyMotion.so");
solver            sixDoFRigidBodyMotion;
sixDoFRigidBodyMotionCoeffs
    patches         (CYLINDER);
    innerDistance   1; // motion area
    outerDistance   2; // dynamic mesh area
    mass            9.97; // mass
    centreOfMass    (0 0 0.29);
    momentOfInertia (0.055 0.055 1);
    g               (0 0 -9.81);
    orientation
        1 0 0
        0 1 0
        0 0 1
    angularMomentum (0 0 0);
    rhoName         rhoInf;
    rhoInf          1000;
    report          on;
    constraints
        maxIteration 500;
        noRotate1
            sixDoFRigidBodyMotionConstraint axis;
            axis            (0 0 1);
        noRotate2
            axis            (1 0 0);
        noRotate3
            axis            (0 1 0);
        zPlane
            sixDoFRigidBodyMotionConstraint plane;
            normal          (0 0 1);
    restraints
        verticalSpring1
            sixDoFRigidBodyMotionRestraint linearSpring;
            anchor          (2 0 0);//spring attached point on bottom
            refAttachmentPt (1 0 0.384);//spring attached point on cylinder
            stiffness       2.3225;
            damping         0.109;
            restLength      1;//?
        verticalSpring2
            anchor          (0 -2 0);//spring attached point on bottom
            refAttachmentPt (0 -1 0.384);//spring attached point on cylinder
            stiffness       2.3225;
            damping         0.109;
            restLength      1;//?
        verticalSpring3
            anchor          (-2 0 0);//spring attached point on bottom
            refAttachmentPt (-1 0 0.384);//spring attached point on cylinder
            stiffness       2.3225;
            damping         0.109;
            restLength      1;//?
        verticalSpring4
            anchor          (0 2 0);//spring attached point on bottom
            refAttachmentPt (0 1 0.384);//spring attached point on cylinder
            stiffness       2.3225;
            damping         0.109;
            restLength      1;//?
Hi Maimouna,
here is my dynamicMeshDict
the only one which I am not sure is the restLength.
I have 4 verticalSpring attached on the cylinder
Best wishes,
Scabbard
Scabbard is offline   Reply With Quote
Old   June 16, 2014, 09:38
ok
Maimouna is on a distinguished road
Dear Scabbard,
many thanks. What about pointDisplacement file and motionU?
Maimouna is offline   Reply With Quote
Old   June 16, 2014, 10:19
Dear Scabbard,
Hi Maimouna,
Do not need to put motionU in to the 0, MotionScale will be automatically generated.
Best wishes,
Scabbard
Old   June 16, 2014, 10:47
ok
In my case, I deleated pointDisplacement and pointMotionU, but it gives me this error message
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: sixDoFRigidBodyMotion
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : libsixDoFRigidBodyMotion.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "libsixDoFRigidBodyMotion.so"
--> FOAM Warning :
From function dlLibraryTable:pen(const dictionary&, const word&, const TablePtr&)
in file /home/maimouna/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/dlLibraryTableTemplates.C at line 67
Could not open library "libsixDoFRigidBodyMotion.so"
--> FOAM FATAL ERROR:
solver table is empty
From function motionSolver::New(const polyMesh& mesh)
in file motionSolver/motionSolver/motionSolver.C at line 117.
FOAM exiting
What does it mean? What's the problem?
Regards
Old   June 16, 2014, 10:50
[/COLOR]
Regards
Hi Maimouna,
which version of OpenFoam are you using?
Best wishes,
Scabbard
Old   June 16, 2014, 10:55
ok
Dear Scabbard, I'm using OpenFOAM-2.2.2.
Old   June 16, 2014, 10:57
Could you send your case to me, so I can test whether it can run on Openfoam
Best wishes,
Scabbard
Old   June 16, 2014, 11:07
ok
Dear Scabbard,
I attached you my case.
With million of thanks.
Old   June 16, 2014, 11:23
Dear Scabbard,
Seems like you use anther mesh tools which I do not have.
Best wishes,
Scabbard
Old   June 16, 2014, 11:31
ok
Dear Scabbard,
what mesh tools you used in your case?
Old   June 16, 2014, 11:37
Dear Scabbard,
Hi Maimouna,
ICEM is the tools which I use, because your polyMesh only have the boundary so
I can not run the case
Best wishes,
Scabbard
Old   June 16, 2014, 11:43
ok
Dear Scabbard,
my running case is following these steps
./Allclean
./Allprepare
pimpleDyMFoam
Old   June 16, 2014, 11:51
Dear Scabbard,
./Allclean
./Allprepare
pimpleDyMFoam
Hi Maimouna
It is seems like I do not have the gmsh.
Best wishes,
Scabbard
Old   June 16, 2014, 11:58
ok
Hi Maimouna
Best wishes,
Scabbard
Dear Scabbard,
no worries, I'll try to solve the problem.
Best wishes
Maimouna
Old   September 15, 2014, 11:11
Default Naturally vibration of the circular cylinder
  #55
ok
Dear OpenFOAM user,
I'm trying to let the cylinder moves in both x and y direction. I'm using for that OF230 and pimpleDyMFoam solver. It's moves in x direction itself and y direction itself. Now, I'm trying to keep it moves in x and y direction naturally at the same time. This is my dynamisMeshDict file
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
// D = 1m (r=0.5); L=1m
// Volume of cylinder V = D^2*pi/4 * L = 1^2*pi/4 * 1 = 0.25*pi
    patches         (cylinder);
    innerDistance   0.35;  //??
    outerDistance   2.5;   //??
    mass             9.97;    // m = 9.97 => rho_cylinder = m/V = 12.6946 [kg/m^3] ??only??
    centreOfMass     (4 0 0.5); //was (0 0 0.29); (Overall domain bounding box (0 -4 0) (16 4 1))
    momentOfInertia  (1.4539 1.4539 1.24625);//J = m*(1/12*(3*r^2 + L^2)  1/12*(3*r^2 + L^2)  r^2/2)
                                            //J = m*(0.14583   0.14583  0.125)
    g               (0 -9.81 0); //was (0 0 -9.81);
    orientation
        1 0 0
        0 1 0
        0 0 1
    rhoName         rhoInf;
    rhoInf          1;  // rho_cylinder is very small for this
    report          on;
    constraints
        maxIteration 500;
        noRotate1
            axis            (0 0 1);
        noRotate2
            axis            (1 0 0);
        noRotate3
            axis            (0 1 0);
       // xLine
       //     sixDoFRigidBodyMotionConstraint line;
       //     direction       (1 0 0);
       // yLine
       //     direction       (0 1 0);
       // zAxis
       //     sixDoFRigidBodyMotionConstraint axis;
       //     axis            (0 0 1);
        zPlane
            normal          (0 0 1);
    restraints  //motion is constrained to z=const plane, so linear springs are neaded only for x and y direction.
        horisontalSpring
            anchor          (4 0 0.5); // was (0.2 0 0);//?
            refAttachmentPt (4 0 0.5); // was (0.092 0 0.384);//spring attached point on cylinder
            stiffness       4000;//?
            damping         2;//?
            restLength      0;//??
        verticalSpring
            anchor          (4 0 0.5);
            stiffness       4000;//?
            damping         2;//?
            restLength      0;//??
     //spring
      //      sixDoFRigidBodyMotionRestraint linearSpring;
      //      anchor          (4 0 0.5); // was (0.2 0 0);//?
      //      refAttachmentPt (4 0 0.5); // was (0.092 0 0.384);//spring attached point on cylinder
      //      stiffness       4000; //2.3225;// you should calculate it for your problem
      //      damping         2; //0.001;// this may be 0 or calculated for your problem
     //       restLength      0;
Could you please check it for me. What's wrong? How to make cylinder moves in both directions? Are there any constraints problem? What about spring stiffness and damping, are they ok? What else?
Any answer would be welcomed?
Thanks in advanced and regards.
Maimouna
Old   September 27, 2014, 07:40
Alireza Heidari
alirezahd is on a distinguished road
Hi Scabbard,
Best regards
Maimouna
hi dear Maimouna
i did the oscillation on cylinder using OF 2.0.1 everything seems ok but i cant valid my result by comparing the lift coeffs. i've downloaded your case but you said it works on OF versions (2.2.2 and 2.3.0) so unfortunately i couldn't run your file and compare it.
my problem is how to define measure of omega in ponitDisplacement file. according to the papers lock in occurs in 0.9<F<1.1 that F=f0/fs where f0 is the forced oscillation frequency and fs refers to the Strouhal frequency for
the fixed cylinder.
in my case Re=100 u=0.004016 d=0.025 St@Re100=0.165 so fs=0.0265 for F=1 f0=fs then omega is 2*pi*0.0265=0.166
is it right way or not? or problem is in my code?
Thanks and Regards,
alireza heidari.
alirezahd is offline   Reply With Quote
Old   September 27, 2014, 12:05
ok
Dear Alireza,
what's the problem in my case? What's the error you get?
Could you please send me your case to have a look? My email: may78may@hotmail.com.
Kind regards
Old   September 28, 2014, 15:11
Retired Super Moderator
Bruno Santos
Greetings to all!
@Maimouna: It's possible that you've stumbled upon a bug that was present in OpenFOAM 2.3.0 and that might have been already been fixed in 2.3.x. I'm referring to this bug report: http://www.openfoam.org/mantisbt/view.php?id=1284
You might want to try OpenFOAM 2.2.2, since on that bug report it states how a certain feature use to work in 2.2.2, but no longer worked in 2.3.0.
In addition, have a look into the tutorial "mesh/moveDynamicMesh/simpleHarmonicMotion" in 2.2.2. It's a very simple tutorial and it makes it a lot easier to test the parameters for restraints, stiffness and so on. The difference is that this motion is based on gravity+springs only and controlled in the file "0/pointDisplacement".
This tutorial is no longer present in OpenFOAM 2.3... or at least I can't find it ... then again, it might be this tutorial: "multiphase/potentialFreeSurfaceDyMFoam/oscillatingBox" - although it's not controlled in the same way
Best regards,
Bruno
Old   October 1, 2014, 09:43
ok
Dear Bruno,
lots of thanks for your post. Regarding what you posted #58, I swiched my case from OF-2.3.0 to OF-2.2.2. My pointDisplacement file is
|  \\    /   O peration     | Version:  2.2.2                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       pointVectorField;
    location    "0.01";
    object      pointDisplacement;
dimensions      [0 1 0 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    cylinder
        type            sixDoFRigidBodyDisplacement;
        mass            9.97;
        orientation
            1 0 0
            0 1 0
            0 0 1
        velocity        (0 0 0);
        acceleration    (0 0 0);
        torque          (0 0 0);
        rhoName         rhoInf;
        rhoInf          1;
        g               (0 -9.81 0);
        report          on;
        constraints
            maxIterations   500;
       /* noRotate1
            sixDoFRigidBodyMotionConstraint fixedAxis;
            axis            (0 0 1);
        noRotate2
            axis            (1 0 0);
        noRotate3
            axis            (0 1 0);
       fixedLine1
            sixDoFRigidBodyMotionConstraint fixedLine;
            tolerance        1e-9;
            relaxationFactor 0.7;
            fixedLineCoeffs
              refPoint        (4 0 0.5);
              direction       (1 1 0);
        fixedLine2
            tolerance        1e-9;
            fixedLineCoeffs
              refPoint        (4 0 0.5);
              direction       (1 1 0);
        restraints
          horizontalSpring
            linearSpringCoeffs
            damping         2; //0.109;
            restLength      0;//??
        verticalSpring
            linearSpringCoeffs
            anchor          (4 0 0.5);
            stiffness       4000;//?
            damping         2;//?
            restLength      0; //1;//??
       /*axialSpring
                sixDoFRigidBodyMotionRestraint linearAxialAngularSpring;
                linearAxialAngularSpringCoeffs
                    axis            (0 0 1);
                    stiffness       700;
                    damping         0.5;
                    referenceOrientation $orientation;
        omega         1.14040;
        amplitude     (0 0.25 0);
        value           uniform (0 0 0);
    top
        type            empty;
    bottom
        type            empty;
         type            fixedValue;
and my dynamicMeshDict file is
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      motionProperties;
motionSolverLibs ("libfvMotionSolvers.so");
solver            displacementLaplacian;
displacementLaplacianCoeffs
    diffusivity       inverseDistance (cylinder);
Could you please check that two files for me please to make cylinder move as shown in https://www.youtube.com/watch?v=oJNMrFnNaeg. I'm looking for oscillating in both direction. Any idea please? Any additions and/ or corrections in that files?
Thanks and regards.
Maimouna
Last edited by wyldckat; October 4, 2014 at 11:02. Reason: Changed [QUOTE][/QUOTE] to [CODE][/CODE]
Old   October 5, 2014, 14:11
Bruno Santos
Hi Maimouna,
I'll write this post as a diary of my progress while examining your files and the case at hand. I'm using the case from post #48 as a base, then replaced the files you indicated in the post above. I used OpenFOAM 2.2.x, but should also with 2.2.2... at least I hope so.
  1. Unpacked your case and replaced the files.
  2. Did some cleaning up, removing backup files "*~" and fixed indentation inside some files.
  3. Then opened the files for the tutorial case "mesh/moveDynamicMesh/simpleHarmonicMotion" from OpenFOAM 2.2.x.
  4. Then searched for the source code of the linear spring:
    find $FOAM_SRC -name "*linearSpring*"
    With that I found the file "linearSpring.H" and this in particular:
            //- Anchor point, where the spring is attached to an immovable
            //  object
            point anchor_;
            //- Reference point of attachment to the solid body
            point refAttachmentPt_;
            //- Spring stiffness coefficient (N/m)
            scalar stiffness_;
            //- Damping coefficient (Ns/m)
            scalar damping_;
            //- Rest length - length of spring when no forces are applied to it
            scalar restLength_;
    Seems pretty clear what each coefficient stands for.
  5. Then I started comparing the "pointDisplacement" field set-up between cases and removed all what seemed excessive to me, since I was still trying to figure things out. Then boosted the U inlet to 100.0 m/s and simplified the BCs to the usual fixed value + zeroGradient inlet and outlet. Oh, and I relaxed a lot the damping and stiffness, so that I could clearly see where the cylinder were floating to. The case I ended up is attached as "freeOscillatingCylinder_v0.1.tar.gz". You'll notice I reduced the time settings to simulate 0.1 s only, saving each 0.01. Quick and dirty results gets us faster through the trial-and-error phase.
I think that now you can start working towards your desired test case. Study the files inside the attached case.
Run the attached case to get a feeling of how my thinking in trying to isolate-and-conquer each setting, one at a time.
Then start from this case to do small changes. First gradually change and test the "horizontalSpring" parameters to suit your case. Then try adding back the "verticalSpring". Then reduce the inlet speed from 100 to 10 and later to 1.
Always run in between changes, to see the results. This way you'll slowly but steadily find how to properly configure your case.
Only when things seem to be working properly, should you start turning on the additional features, such as the functions objects and the long run times.
Best regards,
Bruno
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 22:09
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 08:03
dynamic mesh refinement and rhoCentralFoam ChrisA OpenFOAM Running, Solving & CFD 1 March 21, 2013 08:00
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
