wmake error in compiling icoFoam
Like Tree1Likes
  • 1 Post By nimasam
Old   May 20, 2013, 04:48
Default wmake error in compiling icoFoam
reza
haghgoo_reza is on a distinguished road
Hello All,
I am a new user of OpenFOAM and I have already installed OpenFOAM 2.2.0 on ubuntu.
I'm trying to run the command "wmake" for icoFoam but it does not work. the out put is:
mkdir: cannot create directory `linux64GccDPOpt': Permission denied
/bin/sh: 1: cannot create linux64GccDPOpt/options: Directory nonexistent
make: *** [linux64GccDPOpt/options] Error 2
/opt/openfoam220/wmake/MakefileFiles:40: linux64GccDPOpt/options: No such file or directory
make: *** No rule to make target `linux64GccDPOpt/options'. Stop.
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /opt/openfoam220/applications/solvers/incompressible/icoFoam
could you please help me understand what is wrong with it?
haghgoo_reza is offline   Reply With Quote
Old   May 20, 2013, 08:45
Nima Samkhaniani
nimasam is on a distinguished road
Dear Reza
you installed a deb package, so your source files are in /opt address.
in opt you dont access to writing permission you should be root,
so you can go to Make folder, and in file and change the address where binary file is going to be created to user it would be like
this:
EXE = $(FOAM_USER_APPBIN)/icoFoam
this would solve your problem
mcfdma likes this.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   May 20, 2013, 16:59
Retired Super Moderator
Bruno Santos
Greetings to all!
@Reza: To add to the answer by Nimasam, I suggest that you have a look into this tutorial: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam - from it you should be able to learn how to create a modified OpenFOAM based solver.
Best regards,
Bruno
Old   May 20, 2013, 20:44
Default wmake error
reza
Thank you both Nima and Bruno for your reply.
I uninstalled the Deb pack and installed source pack on my system. Apparently, it does work well.
Cheers
Reza
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 13:28
