floating point exception !!
Old   May 17, 2013, 08:37
Default floating point exception !!
Samer
SamerAli is on a distinguished road
Dear all
I am trying to solve thermal fluid structure interaction, but when i execute my solver it solves temperature for fluid then transfer the heat flux as boundary condition to the solid then solve the solid, but when it starts to solve the solid it give me floating point exception error, how can i know whats wrong:
DILUPBiCG: Solving for T, Initial residual = 1, Final residual = 5.6353e-20, No Iterations 2
DILUPBiCG: Solving for T, Initial residual = 0.107431, Final residual = 9.23625e-13, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 0.0970899, Final residual = 2.78566e-13, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 0.0837568, Final residual = 1.86213e-13, No Iterations 1
DILUPBiCG: Solving for T, Initial residual = 0.0962305, Final residual = 2.08175e-13, No Iterations 1
Setting Heat Flux on solid patch
Total HeatFlux on plate -5.45029e-14
Total HeatFlux on cylinder 1.78303e-13
DICPCG: Solving for T, Initial residual = 1, Final residual = 3.57181e-14, No Iterations 2
Floating point exception (core dumped)
can anyone helps ?
SamerAli is offline   Reply With Quote
Old   May 18, 2013, 03:43
HECKMANN Frédéric
fredo490 is on a distinguished road
If you don't give information about your solver and your case, nobody can help you
fredo490 is offline   Reply With Quote
Floating point exception with pimpleDyMFoam ebah6 OpenFOAM Running, Solving & CFD 9 November 1, 2017 05:58
Inlet Velocity Profile BC - Floating Point exception during solution initialization Janshi STAR-CCM+ 4 March 14, 2012 10:21
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 16:23
Pipe flow in settlingFoam floating point exception jochemvandenbosch OpenFOAM Running, Solving & CFD 4 February 16, 2012 03:24
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
