OpenFoam Doesn't recognize LESModel as a valid selection
Old   April 11, 2013, 08:15
Default OpenFoam Doesn't recognize LESModel as a valid selection
Tom Witten
thomas99 is on a distinguished road
Hi All,
Using the the thread:
http://www.cfd-online.com/Forums/ope...lent-flow.html
I managed to add temperature to pisoFoam for use in LES computations. Everything seems to compile fine but when I run a test case I get an error message telling:
Unknown turbulenceModel type LESModel
Valid turbulenceModel types:
1
laminar
When I switch to a laminar case everything seems to run but I would like to do LES.
I have searched the forums but have been unable to find a solution. Does anyone have an answer? The case is too large to post. I have posted instead the code files. Thanks in advance.
Regards,
Tom
thomas99 is offline   Reply With Quote
Old   April 14, 2013, 10:49
Retired Super Moderator
Bruno Santos
Greetings Tom,
The one I've attached seems to work, at least in OpenFOAM 2.2.
Please, for the next time you have a similar issue:
  1. Even if your case is too big, you could have adapted one of OpenFOAM's tutorials. I had to adapt the tutorial "incompressible/pisoFoam/les/pitzDaily" in order to test pisoTFoam .
  2. The package you provided was not ready to be tested. It only provided the source code files, it did not provide the file "Make/files" and "Make/options".
    And it was not packed inside a folder, which is therefore considered to be a tarbomb: http://en.wikipedia.org/wiki/Tar_%28...mat%29#Tarbomb
    • Anyway, what I did was to copy the source code of "pisoFoam" and adapt accordingly:
      cp -r $FOAM_APP/solvers/incompressible/pisoFoam pisoTFoam
edit: oops, sorry, I had forgotten to attach the file
Best regards,
Bruno
Last edited by wyldckat; April 14, 2013 at 12:49. Reason: forgot to attach the file...
Old   April 16, 2013, 08:48
Tom Witten
Hi Bruno,
Thanks for the answer. After some testing and reading what you said it seems that there was no problem with my code but with compiling. I tried on another computer with another OpenFOAM installation and it worked. Although I am working on a Linux machine I guess the proper libraries were not being included...maybe an issue with my installation...but i can sort that out.
Sorry about not posting properly...next time I'll do it right.
Best regards,
Tom
Old   September 11, 2013, 19:49
Default pisoTFoam
Simon Emhardt
Gosi is on a distinguished road
hi bruno,
i want to run a LES calculation for a rotating pipe with the boundary conditions of constant heat flux or constant temperature.
i want to evaluate the rms of temperature fluctuations, streamwise turbulent heat flux, azimuthal turbulent heat flux, wall-normal turbulent heat flux and reynold shear stress.
is this possible?
could you give me some more information about pisoTFoam?
What is this solver actually calculating?
best regards
simon
Gosi is offline   Reply With Quote
Old   September 14, 2013, 09:24
Bruno Santos
Greetings Simon,
I simply fixed the broken dependency that the solver had. As indicated in the first post, read this thread: http://www.cfd-online.com/Forums/ope...lent-flow.html
The simplest tutorial on this topic is this one: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
As for what you want to do: I think it is all possible to do with OpenFOAM, or at least with the help of ParaView.
As for how to actually achieve each task, I suggest you create a new dedicated thread to this case of yours and detail your case and intended calculations, as explained here: http://www.cfd-online.com/Forums/ope...-get-help.html
Best regards,
Bruno
lesmodel, pisofoam, temperature
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Critical errors during OpenFoam installation in OpenSuse 11.0 amscosta OpenFOAM 5 May 1, 2009 14:06
OpenFOAM Training and Workshop Zagreb 2628Jan2006 hjasak OpenFOAM 1 February 2, 2006 21:07
