Viscous term expansion
Old   March 23, 2011, 07:35
Default Viscous term expansion
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi all, I'm studying the implementation of the viscous term in NS equations in the general framework used for example in pisoFoam, nevertheless I can't understand some of the things that are done. Viscous term is:
div[nuEff*(grad(U)+grad(U)^T)]
due incompressibility and applying div to the product, it becomes
laplacian(nuEff, U)+ grad(nuEff)*[(grad(U)+grad(U)^T)] (1)
in laminar regime nuEff=nu and in turbulent regime nuEff=nu+nut. Reading the code we have from pisoFoam.C:
00065             fvVectorMatrix UEqn
00066             (
00067                 fvm::ddt(U)
00068               + fvm::div(phi, U)
00069               + turbulence->divDevReff(U)
00070             );
so that the viscous term is contained in turbulence->divDevReff(U) calling. Taking, for example, the kEpsilon.C implementation:
00181 tmp<fvVectorMatrix> kEpsilon::divDevReff(volVectorField& U) const
00182 {
00183     return
00184     (
00185       - fvm::laplacian(nuEff(), U)
00186       - fvc::div(nuEff()*dev(fvc::grad(U)().T()))
00187     );
00188 }
the laplacian term is present, but the second term is completely different to the second one in (1). I tried to derive the above formulation without success and my advisor showed me that both expressions [(1) and which is present in divDevRefff] give different results in deed, using a counterexample with a div(U)=0 field.
All ideas are welcome.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   December 13, 2011, 20:44
piccinini is on a distinguished road
Hello, Santiago.
Perhaps you have it already solved, but here goes my try:
The laminar part of viscous stress tensor is:
\nabla\cdot\tau = \nabla \cdot \nu [ \nabla U + ( \nabla U )^T ]
The turbulent part of viscous stress tensor is
\nabla\cdot\tau_T = \nabla \cdot \nu_T [ \nabla U + ( \nabla U )^T ]
Now, summing both contributions:
\nabla\cdot(\tau+\tau_T) =  \nabla\cdot[(\nu+\nu_T) \nabla U] + \nabla \cdot [ (\nu+\nu_T) (\nabla U )^T]
The last term in OpenFOAM code is not the same, though:
- it is computed the deviatoric of (\nabla U )^T and not the gradient itself. This is discussed in another topic: http://www.cfd-online.com/Forums/ope...ivdevreff.html
The trace of last term is zero because of the explicit formulation using the velocity field from previous time step, that should be divergence free.
piccinini is offline   Reply With Quote
Viscous term in Navier Stokes Equations dandalf Main CFD Forum 8 December 13, 2017 16:27
Viscous work term query siw CFX 1 December 6, 2010 06:41
viscous term in energy equation seb62 OpenFOAM Running, Solving & CFD 0 March 19, 2009 03:41
Re: viscous source term mt Phoenics 10 February 11, 2005 10:46
Is the viscous dissipation term fully included? yann Phoenics 0 June 5, 2003 10:23
