April 3, 2013, 04:30 |
Prandtl's one-equation RAS turbulence model
Julien
Hi every Foamers,
I would like to run a steady-state external aerodynamics in Atmospheric Boundary Layer, using the Prandtl's one-equation model with L the mixing length being proportional to the wall distance (something similar to wallDist(mesh_) from LES PrandtlDelta ). But I can't find any RAS turbulence models (incompressibleRASModels, Foam user guide p.U-100) corresponding! The unique 1 equation model is Spalart-Allmaras but seems very complicated for me. Does anybody has already implemented the Prandtl's one-equation model for RAS incompressible model ? It seems quite simple to do so. Do you know why it has not been done within OpenFOAM ? |
June 8, 2015, 15:16 |
Searching for the same,
Any luck!?
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
June 9, 2015, 03:59 |
Julien
unfortunately, no. No answers, and I did not find. I know another software, Meteodyn WT, using this kind of turbulence modelling, but I wanted to make comparisons... |
April 9, 2016, 06:30 |
Benoit
Rep Power: 10 |
Hey guys,
Actually the Prandlt model can be implemented as the oneEqEddies in LES framework. The values of the length is based on the physical of the flows. Ck = 1, Ce = 0.08. With verification, the turbulent kinetic energy is, as expected, the variance (as in RANS) and not the tke of the subgridscale (LES) |
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 20:21 |
[OpenFOAM-2.1.0] kklOmega RAS Turbulence Model (low Re) | alquimista | OpenFOAM Running, Solving & CFD | 64 | June 17, 2016 14:39 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
Use of 1 equation turbulence model in CFX 4.3 | Niels Deen | CFX | 0 | July 19, 2000 08:50 |
