Prandtl's one-equation RAS turbulence model
Old   April 3, 2013, 04:30
Default Prandtl's one-equation RAS turbulence model
Julien
Djub is on a distinguished road
Hi every Foamers,
I would like to run a steady-state external aerodynamics in Atmospheric Boundary Layer, using the Prandtl's one-equation model with L the mixing length being proportional to the wall distance (something similar to wallDist(mesh_) from LES PrandtlDelta ).
But I can't find any RAS turbulence models (incompressibleRASModels, Foam user guide p.U-100) corresponding! The unique 1 equation model is Spalart-Allmaras but seems very complicated for me.
Does anybody has already implemented the Prandtl's one-equation model for RAS incompressible model ? It seems quite simple to do so. Do you know why it has not been done within OpenFOAM ?
Djub is offline   Reply With Quote
Old   June 8, 2015, 15:16
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Searching for the same,
Any luck!?
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   June 9, 2015, 03:59
Julien
unfortunately, no. No answers, and I did not find. I know another software, Meteodyn WT, using this kind of turbulence modelling, but I wanted to make comparisons...
Old   April 9, 2016, 06:30
Benoit
Garusen is on a distinguished road
Hey guys,
Actually the Prandlt model can be implemented as the oneEqEddies in LES framework. The values of the length is based on the physical of the flows. Ck = 1, Ce = 0.08.
With verification, the turbulent kinetic energy is, as expected, the variance (as in RANS) and not the tke of the subgridscale (LES)
Garusen is offline   Reply With Quote
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 20:21
[OpenFOAM-2.1.0] kklOmega RAS Turbulence Model (low Re) alquimista OpenFOAM Running, Solving & CFD 64 June 17, 2016 14:39
error message cuteapathy CFX 14 March 20, 2012 06:45
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
Use of 1 equation turbulence model in CFX 4.3 Niels Deen CFX 0 July 19, 2000 08:50
