cavity tutorial: cannot find file p
Like Tree1Likes
  • 1 Post By Garusen
Old   May 17, 2013, 11:19
Default cavity tutorial: cannot find file p
M. C.
student666 is on a distinguished road
Hi to all,
I'm trying to learn openfoam foundamentals, by reproducing tutorial case; first is cavity.
I'm using gmsh as mesher.
Calculations dosen't proceed as for the following error:
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/kebalinux/OpenFOAM/kebalinux-2.1.1/run/test/cavity/0/p at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
any way file p is on case directory, what am i missing?
student666 is offline   Reply With Quote
Old   August 1, 2013, 11:28
Philip Brown
Phizz82 is on a distinguished road
Is the file in directory 0?
Also, could you post what the contents of p are please.
Phizz82 is offline   Reply With Quote
Old   August 17, 2015, 19:59
Nevada
razi.me05 is on a distinguished road
Hi did you find out what was it for. I have the same problem. I'll really appreciate your help.
razi.me05 is offline   Reply With Quote
Old   August 31, 2015, 04:19
Benoit
Garusen is on a distinguished road
Razi, sometimes in tutorials, files in 0 directories are named X.org instead of X (to keep original files). So rename or copy and rename the file for p maybe also for U).
razi.me05 likes this.
Garusen is offline   Reply With Quote
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
