May 17, 2013, 11:19 |
cavity tutorial: cannot find file p
Hi to all,
I'm trying to learn openfoam foundamentals, by reproducing tutorial case; first is cavity. I'm using gmsh as mesher. Calculations dosen't proceed as for the following error: Create time Create mesh for time = 0 Reading transportProperties Reading field p --> FOAM FATAL IO ERROR: cannot find file file: /home/kebalinux/OpenFOAM/kebalinux-2.1.1/run/test/cavity/0/p at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting any way file p is on case directory, what am i missing? |
August 1, 2013, 11:28 |
Philip Brown
Rep Power: 12 |
Is the file in directory 0?
Also, could you post what the contents of p are please. |
August 17, 2015, 19:59 |
Nevada
Rep Power: 12 |
Hi did you find out what was it for. I have the same problem. I'll really appreciate your help.
August 31, 2015, 04:19 |
Benoit
Rep Power: 10 |
Razi, sometimes in tutorials, files in 0 directories are named X.org instead of X (to keep original files). So rename or copy and rename the file for p maybe also for U).
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
