May 21, 2014, 20:00 |
What do the scripts Allrun do?
starter
Rep Power: 15 |
Hi
I am not very good in openfoam. can you kindly advise what does Allrun script do. Thanks in advance |
May 24, 2014, 03:16 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings sihaqqi,
If you edit one of the various "Allrun" scripts, you'll see its content. It will reveal that each script is specially structured for running most of the steps of a tutorial case, such as meshing, decomposing, simulating, sampling and reconstructing. To run the Allrun scripts, you'll need to use the relative path to it, like this: Code:
./Allrun edit: In case you copied the script from somewhere else and it lost the permissions to execute, then run this command to restore said permission to execute the script: Code:
chmod +x Allrun Bruno
Ubuntu: Allrun script issue | fletc900 | OpenFOAM Bugs | 2 | July 2, 2010 16:58 |
ICEM CFD Scripts | Vinod Dhiman | Main CFD Forum | 2 | February 17, 2010 10:56 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
How to use the Allrun Alltest scripts for the tutorials | david_flo1 | OpenFOAM | 1 | February 21, 2008 03:21 |
Experimental Repository for UDFs, Journal Files and Scheme Scripts | Jonas Larsson | FLUENT | 0 | March 5, 2000 15:36 |
