What do the scripts Allrun do?
Like Tree1Likes
  • 1 Post By wyldckat
Old   May 21, 2014, 20:00
Default What do the scripts Allrun do?
starter
sihaqqi is on a distinguished road
Hi
I am not very good in openfoam. can you kindly advise what does Allrun script do.
Thanks in advance
sihaqqi is offline   Reply With Quote
Old   May 24, 2014, 03:16
Retired Super Moderator
Bruno Santos
Greetings sihaqqi,
If you edit one of the various "Allrun" scripts, you'll see its content. It will reveal that each script is specially structured for running most of the steps of a tutorial case, such as meshing, decomposing, simulating, sampling and reconstructing.
To run the Allrun scripts, you'll need to use the relative path to it, like this:
./Allrun
For more information on how to use the command line in Linux distributions, please study this or any other similar tutorials: http://linuxcommand.org/learning_the_shell.php
edit: In case you copied the script from somewhere else and it lost the permissions to execute, then run this command to restore said permission to execute the script:
chmod +x Allrun
Best regards,
Bruno
zfaraday likes this.
Ubuntu: Allrun script issue fletc900 OpenFOAM Bugs 2 July 2, 2010 16:58
ICEM CFD Scripts Vinod Dhiman Main CFD Forum 2 February 17, 2010 10:56
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
How to use the Allrun Alltest scripts for the tutorials david_flo1 OpenFOAM 1 February 21, 2008 03:21
Experimental Repository for UDFs, Journal Files and Scheme Scripts Jonas Larsson FLUENT 0 March 5, 2000 15:36
