IcoUncoupledKinematicParcelFoam: getting sigsegv after adding particle
Like Tree1Likes
  • 1 Post By Subhasree
Old   October 11, 2015, 17:03
Default IcoUncoupledKinematicParcelFoam: getting sigsegv after adding particle
Subhasree
Subhasree is on a distinguished road
Hi EveryOne,
I am working on a simple 3-D model to simulate particle flow through a rectangular domain. I have initially simulated it using laminar pisoFoam and no using its velocity field to simulate the particle flow.
But on running icoUncoupledKinematicParcelFoam, I am getting the following error. I have attached a snap-shot of the error. I am new for this solver and am unable to understand. Please help!
Subhasree is offline   Reply With Quote
Old   October 12, 2015, 15:55
Retired Super Moderator
Bruno Santos
Quick answer: "sigsegv" https://en.wikipedia.org/wiki/Segmentation_fault - is a segmentation fault due to a bad access to memory.
Can you please provide a test case?
Old   November 17, 2015, 02:34
Default icoLagrangianFoam solver
Subhasree
Thanks! I have solved that problem. Presently I am working on using a modified icoLagrangianFoam Solver. Actly I am using adjustable time step. After making all the required modifications as I am using wmake I am getting the following error:
/home/subhasree/foam/foam-extend-3.1/src/finiteVolume/lnInclude/readPISOControls.H:8:10: warning: unused variable ‘momentumPredictor’ [-Wunused-variable]
bool momentumPredictor =
/home/subhasree/foam/foam-extend-3.1/src/finiteVolume/lnInclude/readPISOControls.H:11:10: warning: unused variable ‘transonic’ [-Wunused-variable]
bool transonic =
/home/subhasree/foam/foam-extend-3.1/src/finiteVolume/lnInclude/readPISOControls.H:14:9: warning: unused variable ‘nOuterCorr’ [-Wunused-variable]
int nOuterCorr =
icoLagrangianFoam_new.dep:721: recipe for target 'Make/linux64GccDPOpt/icoLagrangianFoam_new.o' failed
make: *** [Make/linux64GccDPOpt/icoLagrangianFoam_new.o] Error 1
Can anybody please suggest how may I solve this problem?
Old   November 17, 2015, 02:52
santhosh
santoo_cfd is on a distinguished road
Can you post full error message. Your post only shows warnings and there is nothing to worry about above warnings about unused variables in my opinion.
santoo_cfd is offline   Reply With Quote
Old   November 17, 2015, 03:54
Subhasree
Please check the last 2 lines in the previous post:
after this the compilation stops in between. I am also attaching the files if required.
Old   December 6, 2015, 15:10
Bruno Santos
Quick answer: I've finally managed to take a quick look into this. The complete output from wmake was this:
Making dependency list for source file icoLagrangianFoam_new.C
SOURCE=icoLagrangianFoam_new.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/ofuser/foam/foam-extend-3.1/src/lagrangian/basic/lnInclude     -I/home/ofuser/foam/foam-extend-3.1/src/lagrangian/intermediate/lnInclude     -I/home/ofuser/foam/foam-extend-3.1/src/finiteVolume/lnInclude     -I/home/ofuser/foam/foam-extend-3.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/ofuser/foam/foam-extend-3.1/src/foam/lnInclude -I/home/ofuser/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/icoLagrangianFoam_new.o
icoLagrangianFoam_new.C: In function ‘int main(int, char**)’:
icoLagrangianFoam_new.C:53:20: error: no match for call to ‘(Foam::Time) ()’
/home/ofuser/foam/foam-extend-3.1/src/foam/lnInclude/Time.H:64:7: note: candidate is:
/home/ofuser/foam/foam-extend-3.1/src/foam/lnInclude/HashTableI.H:145:11: note: T& Foam::HashTable<T, Key, Hash>::operator()(const Key&) [with T = Foam::regIOobject*, Key = Foam::word, Hash = Foam::string::hash]
/home/ofuser/foam/foam-extend-3.1/src/foam/lnInclude/HashTableI.H:145:11: note:   candidate expects 1 argument, 0 provided
/home/ofuser/foam/foam-extend-3.1/src/finiteVolume/lnInclude/readPISOControls.H:8:10: warning: unused variable ‘momentumPredictor’ [-Wunused-variable]
/home/ofuser/foam/foam-extend-3.1/src/finiteVolume/lnInclude/readPISOControls.H:11:10: warning: unused variable ‘transonic’ [-Wunused-variable]
/home/ofuser/foam/foam-extend-3.1/src/finiteVolume/lnInclude/readPISOControls.H:14:9: warning: unused variable ‘nOuterCorr’ [-Wunused-variable]
Therefore, the specific error is this:
Where it refers to this line:
while (runTime())
If we look at the icoFoam solver source code in foam-extend 3.1:
while (runTime.loop())
And with this change, it now builds without problems.
Old   December 8, 2015, 05:46
Smile
Subhasree
Thanks a lot!!! It worked.
wyldckat likes this.
UDF for particle interception with pt_termination fortran routine abcdefgh CFX 6 October 6, 2019 13:30
Particle Interaction is CFX; Adding Interparticle Attraction such as Van Der Waals FrankS CFX 11 November 12, 2013 19:53
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Adding extra compound to coal particle. anthony05 FLUENT 0 July 4, 2013 22:33
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
