free surface elevation"Interpolation for interface capturing" |
May 28, 2022, 04:54 |
Basar H.Ibrahim
Rep Power: 4 |
Hello everybody!
Currently, I'm working on the Wedge entry problem. the wedge is entering the water vertically down with a specified constant speed, when the water is at rest. I'm using OpenFOAM v2106, using dynamicOversetFvMesh and the multiSolidBodyMotionSolver with linearMotion function as I've attached below. Most of the settings I used are taken from the overInterDyMFoam tutorials. I've attached the following files: dynamicMeshDict controlDict fvSchemes fvSolution Unfortunately, I noticed I have a spurious free surface elevator, and the water interface along the wedge doesn't look very good, see the attached pictures. Can anybody give me any advice on where is the problem or which scheme I should use? Any description would be much appreciated! Thanks in advance for your comments! regards, Basar Huzni |
interface advection, interface bc, interface capture, interface compression, scheme file |
What are Free Surface Level and Bottom Level | beratcagan | FLUENT | 1 | December 6, 2021 20:40 |
how to capture free surface cells? | MichaelVS | FLUENT | 1 | June 10, 2015 02:18 |
Floating dok on waves: free surface divergence | Galchenko | CFX | 3 | September 11, 2014 18:04 |
Can Flow-3D plot the free surface area in Iso-surface or colour variable? | therockyy | FLOW-3D | 1 | June 20, 2010 19:36 |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 18:13 |
