I need explanations about fixedFluxPressure
Like Tree164Likes
  • 4 Post By Cyp
  • 2 Post By JR22
  • 38 Post By fabian_roesler
  • 36 Post By fabian_roesler
  • 32 Post By santiagomarquezd
  • 35 Post By ssss
  • 6 Post By decah
  • 8 Post By roenby
  • 2 Post By Andrea1984
  • 1 Post By Mars409
Old   November 30, 2010, 04:15
Default I need explanations about fixedFluxPressure
Cyp
Cyprien
Cyp is on a distinguished road
Hello!
I had a look at the fixedFluxPressure boundary condition and I am not quite sure to well understand what this BC does.
I guess I have to use this BC if I want to evaluate the pressure according to a velocity input. Am I wrong ?
Furthermore, in the code source, one can read:
        gradient() = (phip - (patch().Sf() & Up))/patch().magSf()/rAp;
I do not succeed in linking this snippet with a mathematical formula...
All enlightments are welcome!
Regards,
Cyp
JR22, Guimloute, amuzeshi and 1 others like this.
Cyp is offline   Reply With Quote
Old   August 19, 2013, 20:36
Default buoyantPressure vs. fixedFluxPressure
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
I realize this is an old thread, but it is still very relevant.
I was having terrible problems trying to get buoyantBoussinesqSimpleFoam to converge. I changed the p_rgh BC's from buoyantPressure to fixedFluxPressure and the model started to converge.
Anybody?
Guimloute and amuzeshi like this.
JR22 is offline   Reply With Quote
Old   August 1, 2014, 04:42
Srivathsan N
Sherlock_1812 is on a distinguished road
Same question here. What is the difference between buoyantPressure and fixedFLuxPressure boundary conditions?
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   October 16, 2014, 02:23
Question OpenFAOM 2.3.0 doesn't have buoyantPressure BC
zandi's Avatar
Fatema Zandi Goharrizi
zandi is on a distinguished road
Hi
OpenFAOM version 2.3.0 doesn't have buoyantPressure libraries. Am I right?
what is the difference between buoyantPressure and fixedFluxPressure?
why fixedFluxPressure converge better? is it the only difference between them?
Please help
zandi is offline   Reply With Quote
Old   October 16, 2014, 03:46
Fabian Roesler
fabian_roesler is on a distinguished road
OpenFOAM 2.2.2 has both boundary conditions. In newer Version, buoyantPressure boundary was dismissed. For clarification have a look into the code or into Doxygen.
From buoyantPressureFvPatchScalarField we learn that:
This boundary condition sets the pressure gradient appropriately for buoyant flow. If the variable name is one of pd, p_rgh or ph_rgh, we assume that the pressure variable is and the gradient set using:
Otherwise we assume that it is the static pressure, and the gradient calculated using:
From fixedFluxPressureFvPatchScalarField we see that:
This boundary condition adjusts the pressure gradient such that the flux on the boundary is that specified by the velocity boundary condition.
The predicted flux to be compensated by the pressure gradient is evaluated as , both of which are looked-up from the database, as is the pressure diffusivity used to calculate the gradient using:
fabian_roesler is offline   Reply With Quote
Old   October 16, 2014, 04:21
Fabian Roesler
Some additional remarks:
The fixedFluxPressure boundary is known do have a better convergence. This is in my opinion due to the more pressure related calculation of the gradient:
phi and phiHbyA (predicted flux field) are directly linked to pressure equation. On a wall, the flux difference tends to zero and so the boundary condition turns to zeroGradient.
The buoyanPressure boundary is more the physical method to describe the pressure gradient with Archimedes' principle.
I hope my explanation is understandable and correct.
Cheers
Fabian
Old   November 5, 2014, 16:06
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi folks, I'm dealing with fixedFluxPressure BCs also and this thread was helpful. Checking the code things have changed at least in FOAM 2.3.0. The class definition is now more simple
fixedFluxPressureFvPatchScalarField.C
  125 void Foam::fixedFluxPressureFvPatchScalarField::updateCoeffs
  126 (
  127     const scalarField& snGradp
  128 )
  129 {
  130     if (updated())
  131     {
  132         return;
  133     }
  134
  135     curTimeIndex_ = this->db().time().timeIndex();
  136
  137     gradient() = snGradp;
  138     fixedGradientFvPatchScalarField::updateCoeffs();
  139 }
it only sets the proper gradient in line 137 and then calls the updateCoeffs() method from the fixedGradientFvPatchScalarField class (from which the present class inherits). This requires to set the value of snGradp which is done at solver level. For example, from pEqn.H of interFoam we have:
   27     // Update the fixedFluxPressure BCs to ensure flux consistency
   28     setSnGrad<fixedFluxPressureFvPatchScalarField>
   29     (
   30         p_rgh.boundaryField(),
   31         (
   32             phiHbyA.boundaryField()
   33           - (mesh.Sf().boundaryField() & U.boundaryField())
   34         )/(mesh.magSf().boundaryField()*rAUf.boundaryField())
   35     );
From the new code the gradient reads:
\vec{\nabla}p = \left(\vec{H}/a_P\cdot\vec{S}_f - \vec{U}\cdot\vec{S}_f\right)\frac{(a_P)_f}{||\vec{S}_f||}
Hope this helps for 2.3.0 users.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   April 14, 2015, 16:46
anonymous
ssss is on a distinguished road
I would like to comment out a bit, why does OpenFOAM use the expression given by santiagomarquezd (gracias por el análisis del código fuente) for the pressure surface normal gradient in the boundaries.
First of all we need to write down the momentum equation discretized using the Rhie-Chow interpolation method. This reads:
\vec{u}_f   = \left( \dfrac{\vec{h}}{a_p}\right)_f  - \left( \dfrac{1}{a_p}\right)_f   \nabla p_m
Where the f subscript means interpolate to the face, p_m is the variable p_rgh whose value is p_m=p-\rho \vec{g} \cdot \vec{h}, and the vector u is the velocity. Now multiply the equation by the face surface vector \vec{S}_f = ||S_f|| \cdot \vec{n} where the vector n is the surface normal:
\vec{u}_f \cdot \vec{S}_f   = \left( \dfrac{\vec{h}}{a_p}\right)_f \cdot  \vec{S}_f  - \left( \dfrac{1}{a_p}\right)_f   \nabla p_m \cdot  \vec{S_f}
Thus the following equation for the pressure surface gradient \nabla p_m \cdot \vec{n} can be obtained:
\nabla p_m \cdot \vec{n} =\left ( \left( \dfrac{\vec{h}}{a_p}\right)_f \cdot  \vec{S}_f - \vec{u}_f \cdot \vec{S}_f \right) \dfrac{a_p|_f}{||S_f||}
Hope this is useful for you foamers
ssss is offline   Reply With Quote
Old   October 14, 2015, 13:55
Angel Monsalve
angelmonsalve is on a distinguished road
Thanks for the explanation!!
angelmonsalve is offline   Reply With Quote
Old   August 31, 2016, 14:35
Question value uniform 0;
Jon Elvar Wallevik
JonW will become famous soon enough
Dear all, thank you for the above discussion
There is one thing I don't understand fully. In the damBreak example for interFoam (say of OF 4.0) the b.c. for p_rgh is given as...
leftWall
type fixedFluxPressure;
value uniform 0;
so the question is, what does "value uniform 0;" stand for?
There is one constructor in fixedFluxPressureFvPatchScalarField.C which has 3 arguments:
Foam::fixedFluxPressureFvPatchScalarField::fixedFl uxPressureFvPatchScalarField
const fvPatch& p,
const DimensionedField<scalar, volMesh>& iF,
const dictionary& dict
... and in that function body, there is
if (dict.found("value") && dict.found("gradient"))
But in interFoam, this constructor is not used, since it is the constructor with two arguments that is used (actually the first constructor), c.f. in pEqn.H
- fvOptions.relative(mesh.Sf().boundaryField() & U.boundaryField())
)/(mesh.magSf().boundaryField()*rAUf.boundaryField() )
So am I understanding this correctly: When using interFoam, then the "value uniform 0;" is actually not used?
Any comment would be helpful
J.
JonW is offline   Reply With Quote
Old   November 23, 2016, 17:45
Declan
decah is on a distinguished road
Hi Jon,
I had a similar question about flowRateInletVelocity which requires an input value that doesn't appear to do anything. As explained by Roman in the below thread some derived boundary conditions necessarily inherit a placeholder value like this one because of their basic structure.
http://www.cfd-online.com/Forums/ope...tvelocity.html
I think the value uniform 0; you asked about is like this and could be assigned any value you like without affecting your simulation.
JonW, amolrajan, mizzou and 3 others like this.
decah is offline   Reply With Quote
Old   January 18, 2017, 04:46
Mido
nw_ds is on a distinguished road
So the bottom line, The difference between this bc and zeroGradient is in term of the convergence (HOW MANY ITER TO SOLVE THE PRESSURE EQN ) not the accuracy or whether the solver will converge or not.
nw_ds is offline   Reply With Quote
Old   October 11, 2017, 11:22
beh_zadi is on a distinguished road
Hi openfoam users,
I'm new to openfoam and I need your help about fixedFluxPressure BC. I have made a new solver derived from icoFoam and I didn't find the following code in it while it exists in interFoam.
I specified fixedValue BC for velocity field and fixedFluxPressure for pressure field. Does it need to add the following code in new solver to ensure flux consistency or not?
   29     (
   31         (
   35     );
beh_zadi is offline   Reply With Quote
Old   December 14, 2017, 08:58
Johan Roenby
roenby will become famous soon enough
Just for the record:
If you are using a newer version of OpenFOAM (e.g. 5.x), you will find that the referred code snippet from interFoam's pEqn.H file has been replaced by the function call:
constrainPressure(p_rgh, U, phiHbyA, rAUf, MRF);
This is also the case for icoFoam.
In the source code for this function, you'll find a similar code snippet:
https://github.com/OpenFOAM/OpenFOAM...Pressure.C#L34
Best,
Johan
roenby is offline   Reply With Quote
Old   April 30, 2020, 08:21
Andrea
Andrea1984 is on a distinguished road
Apologies for digging up and old thread.
I have noticed that the call to constrainPressure does not take place in the Eulerian multiphase solvers (I am using OpenFOAM 6.0). I take this means that zeroGradient and fixedFluxPressure are equivalent for this class of solvers. Would be useful is some can confirm this.
Cheers,
Andrea
Andrea1984 is offline   Reply With Quote
Old   April 30, 2020, 09:00
Andrea
Ok so to answer my previous question, in multiphase Eulerian solvers this is done within pEqn without calling the constrainPressure function (probably because this is only suitable for one-fluid solvers).
In twoPhaseEulerFoam's pEqn.H this is done by
        p_rgh.boundaryFieldRef(),
                alphaf1.boundaryField()*phi1.boundaryField()
              + alphaf2.boundaryField()*phi2.boundaryField()
The same is done in the pressure equation of the reactingEulerFoam family.
So to conclude the answer to my question in the previous post is no: fixedFluxPressure and zeroGradient are NOT the same thing in multiphase Eulerian solvers.
granzer and Mars409 like this.
Old   May 27, 2022, 10:01
Mars409 is on a distinguished road
All that updateCoeffs() does, as defined in fvPatchField.C, is setting flag update_ to true:
template<class Type>
 void Foam::fvPatchField<Type>::updateCoeffs()
     updated_ = true;
Mars409 is offline   Reply With Quote
Old   May 28, 2022, 11:01
The fixedFluxPressure boundary condition and the constrainPressure() function are now explained in a detailed openFOAM Wiki article on the SimpleFOAM solver:
https://openfoamwiki.net/index.php/S...ssure_equation
Mahmoud Abbaszadeh likes this.
Rotating objects Marcus Gellert (Gellert) OpenFOAM Running, Solving & CFD 17 December 14, 2010 15:06
muSgsWallFunctionFvPatchField, explanations or bug ? fgal OpenFOAM Bugs 0 July 22, 2010 14:19
FixedFluxPressure cannot find field 1%7cAU anger OpenFOAM Running, Solving & CFD 3 November 10, 2008 05:50
New to CFX-need explanations about mesh parameters Cyril CFX 3 November 24, 2006 06:33
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 09:41
