April 23, 2011, 23:00 |
interDyMFoam
I encountered the following output message when executing interDyMFoam using version 1.7.0 and I am not sure whether I should continue or kill my run, since my linear and angular velocity becomes "nan" as shown below. If anyone can provide me some useful guideline. I greatly appreciated.
Thank you, -------------- Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: displacementLaplacian Selecting motion diffusion: inverseDistance Reading field p_rgh Reading field alpha1 Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } Reading g Calculating field g.h time step continuity errors : sum local = 0, global = 0, cumulative = 0 GAMGPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 Starting time loop Interface Courant Number mean: 0 max: 0 Courant Number mean: 0 max: 0 deltaT = 0.0047619047619 Time = 0.0047619 Centre of mass: (4 0.2 0) Linear velocity: (nan nan nan) Angular velocity: (nan nan nan) |
April 24, 2011, 05:50 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Virtual-iCFD,
Did you run setFields? Did you redefine setFieldsDict for your new volume mesh? Or maybe it's the mesh that isn't moving the way you expected it to!? Another possibility is if you built OpenFOAM 1.7.0 with a gcc 4.5.x, then you must either rebuild it with a gcc 4.4.x or update to OpenFOAM 1.7.1! Best regards, Bruno
April 24, 2011, 18:05 |
Hi Bruno, thank you for your prompt reply.
It is indeed the volume mesh issue which I overlooked the quality from snappyHexMesh. After reran snappyHexMesh with new setting and now my case is running just fine. =) |
angular velocity, interdymfoam, linear velocity |
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 06:35 |
GAMG problem in interDyMFoam? | ribe | OpenFOAM | 4 | July 17, 2013 22:23 |
interDyMFoam with GGI in 3d | stawrogin | OpenFOAM Running, Solving & CFD | 2 | January 5, 2011 02:17 |
error using interDyMFoam with kOmegaSST to simulate sloshing | anmartin | OpenFOAM Running, Solving & CFD | 0 | July 20, 2010 13:21 |
Turning interDymFoam into a turbulence solver | Saúl Balsa | OpenFOAM Running, Solving & CFD | 3 | June 30, 2010 16:09 |
