interDyMFoam
Old   April 23, 2011, 23:00
Default interDyMFoam
Virtual-iCFD is on a distinguished road
I encountered the following output message when executing interDyMFoam using version 1.7.0 and I am not sure whether I should continue or kill my run, since my linear and angular velocity becomes "nan" as shown below. If anyone can provide me some useful guideline. I greatly appreciated.
Thank you,
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: displacementLaplacian
Selecting motion diffusion: inverseDistance
Reading field p_rgh
Reading field alpha1
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
sigmaEps 1.3;
Reading g
Calculating field g.h
time step continuity errors : sum local = 0, global = 0, cumulative = 0
GAMGPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.0047619047619
Time = 0.0047619
Centre of mass: (4 0.2 0)
Linear velocity: (nan nan nan)
Angular velocity: (nan nan nan)
Virtual-iCFD is offline   Reply With Quote
Old   April 24, 2011, 05:50
Retired Super Moderator
Bruno Santos
Greetings Virtual-iCFD,
Is there any fluid or mesh in your case? The Courant Number shouldn't be zero!
Did you run setFields? Did you redefine setFieldsDict for your new volume mesh? Or maybe it's the mesh that isn't moving the way you expected it to!?
Another possibility is if you built OpenFOAM 1.7.0 with a gcc 4.5.x, then you must either rebuild it with a gcc 4.4.x or update to OpenFOAM 1.7.1!
Best regards,
Bruno
Old   April 24, 2011, 18:05
Hi Bruno, thank you for your prompt reply.
It is indeed the volume mesh issue which I overlooked the quality from snappyHexMesh.
After reran snappyHexMesh with new setting and now my case is running just fine. =)
angular velocity, interdymfoam, linear velocity
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 06:35
GAMG problem in interDyMFoam? ribe OpenFOAM 4 July 17, 2013 22:23
interDyMFoam with GGI in 3d stawrogin OpenFOAM Running, Solving & CFD 2 January 5, 2011 02:17
error using interDyMFoam with kOmegaSST to simulate sloshing anmartin OpenFOAM Running, Solving & CFD 0 July 20, 2010 13:21
Turning interDymFoam into a turbulence solver Saúl Balsa OpenFOAM Running, Solving & CFD 3 June 30, 2010 16:09
