problem running buoyantSimpleFoam
Old   August 25, 2011, 19:35
Default problem running buoyantSimpleFoam
Naveen
vetnav is on a distinguished road
I am trying to run a 2D free convection case. The flow geometry is a closed box, the bottom wall is heated with air as the fluid. I have OpenFOAM-2.0.x on Fedora14.
My blockMesh looks like
PHP Code:
convertToMeters 0.01;
vertices
0  0  0)
60  0  0)
60  10  0)
0  10 0)
0 0 1)
60 0 1)
60 10 1)
0 10 1)
edges
blocks
hex (0 1 2 3 4 5 6 7) (120 60 1simpleGrading (1 1 1)
patches
wall top
3 7 6 2)
wall bottom
1 5 4 0)
wall side
2 6 5 1)
0 4 7 3)
    empty
frontAndBack
0 3 2 1)
4 5 6 7)
mergePatchPairs
and my pressure boundary conditions file looks like
PHP Code:
dimensions      [--2 0 0 0 0];
internalField   uniform 101325;
boundaryField
top
type            zeroGradient;
bottom
type            zeroGradient;
side
type            zeroGradient;
frontAndBack
type            empty;
When I try to run the code, I get a Fatal error, the output is as below
PHP Code:
Build  2.0.x-321b2e64c9f9
Exec
buoyantSimpleFoam
Date
Aug 25 2011
Time
15:22:20
Host
naveen
PID
5771
Case   : /home/naveen/OpenFOAM/naveen-2.0.x/run/TwoDfreeconv
nProcs
1
sigFpe
Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking Monitoring run-time modified files using timeStampMaster
allowSystemOperations
Disallowing user-supplied system call operations
Create time
Create mesh
for time 0
Reading g
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo
<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
FOAM FATAL IO ERROR:
patch type 'wall' not constraint type 'empty'
for patch frontAndBack of field p in file "/home/naveen/OpenFOAM/naveen-2.0.x/run/TwoDfreeconv/0/p"
file: /home/naveen/OpenFOAM/naveen-2.0.x/run/TwoDfreeconv/0/p::boundaryField::frontAndBack from line 41 to line 41.
    From
function emptyFvPatchField<Type>::emptyFvPatchField
    const
fvPatchp,
    const
Field<Type>& field,
    const
dictionarydict
in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 100.
FOAM exiting
As you can see the geometry has empty patches. I don't understand why it complains about empty patches. Could anyone please help me.
Thank you
Naveen
vetnav is offline   Reply With Quote
Old   August 26, 2011, 03:14
Dima Risch
dima is on a distinguished road
Hi Naveen
in OpenFOAM-2.0.x the blockMeshDict is different to OpenFOAM-1.7.x
example from the shockTube tutorial
boundary
    sides
        type patch;
        faces
            (1 2 6 5)
            (0 4 7 3)
    empty
        type empty;
        faces
            (0 1 5 4)
            (5 6 7 4)
            (3 7 6 2)
            (0 3 2 1)
and the default type is wall, i think
maybe this could be the reason
regards, Dima
dima is offline   Reply With Quote
Old   August 26, 2011, 12:18
Naveen
Hi dima,
Thank you very much for the reply. Strangely, cavity test case which I copied from 1.7.1 runs fine in 2.0.x. I will try your suggestion and see.
Thank you
Naveen
Problem running buoyantFoam anke OpenFOAM 4 August 28, 2013 04:43
Problem running parallel Hernán Main CFD Forum 0 December 22, 2009 04:36
InterFoam / InterDyFoam running problem anon_c OpenFOAM Running, Solving & CFD 1 August 26, 2009 03:54
the problem of running star-cd after pro-star liu-jinsong Siemens 0 November 20, 2008 20:58
problem running parallel-help needed Shankar FLUENT 0 December 16, 2002 13:45
