what does "cellSet" mean?
Old   August 24, 2011, 09:53
Default what does "cellSet" mean?
桂莹
yingkun is on a distinguished road
hi,
can anybody tell me what does "cellSet" mean and how to set the "cellSetDict"?
yingkun is offline   Reply With Quote
Old   August 24, 2011, 10:21
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi
With cellSet you can define a part of the mesh cells on which you want to do any kind of operation.
You can find a full example of the cellSetDict in the application folder, where cellSet.C lives.
Kind regards,
Niels
ngj is offline   Reply With Quote
Old   August 26, 2011, 04:38
桂莹
Hi,Niels
Thank you for your reply!
I don't really understand what you mean.
I want to use coalChemistryFoam solver to simulate coal combustion based on the case " /lagrangian/coalChemistryFoam/simplifiedSiwek", can you explain more detailed under this situation?(such as which topoSetSource should i use ...)
look forword for your early reply!
Thanks!
Ying
Old   August 26, 2011, 12:46
ngj
Hi
Unfortunately, I do not know the solver you are querying on. However, I can elaborate on cellSet.
When you run cellSet on a computational mesh, a set of cells is generated, which obey to the rules you have defined in cellSetDict. E.g. all cells within a given box defined by the opposite corner points.
What these cells are used for is dependent on the solver, and thus the easiest way to find an answer is to look in the source code or search the forum.
Good luck,
Niels
Old   August 27, 2011, 01:15
桂莹
Hi,Niels
I seem to find what it means in my solver,and what you said are helpful to me
Thank you so much!
