November 9, 2012, 19:44 |
Generate mesh in batch
Rep Power: 14 |
Is it possible in starccm+ to setup all the modeling choices that I want for making a mesh and then to do the meshing in batch instead of interactive mode? The geometry I'm meshing is very complex and meshing takes many hours. I would rather if I could submit the job to the job-queuing system on one of our clusters instead of tying up an interactive node. Furthermore, the computer that I would like to mesh on may not be able to open up a GUI. If this is possible, what is the command that I have to give on the command line?
November 11, 2012, 10:43 |
Rep Power: 17 |
Does this small macro help?
package macro; import java.util.*; import star.common.*; import star.base.neo.*; import star.meshing.*; public class MeshAndSave extends StarMacro { public void execute() { execute0(); } private void execute0() { Simulation sim = getActiveSimulation(); MeshPipelineController msh = sim.get(MeshPipelineController.class); msh.generateSurfaceMesh(); msh.generateVolumeMesh(); sim.saveState("mesh.sim"); } }
Cheers, cfdguy ** Every rose has its thorn ** PS: Please watch this Youtube channel. |
November 12, 2012, 15:19 |
Rep Power: 14 |
I didn't think of using a macro. So how do I start starccm+ and then execute this macro on startup from the command line?
November 13, 2012, 04:22 |
Oliver Lauer
Rep Power: 17 |
Did you ever read the manual?
Try starccm+ -batch name.java case.sim |
November 13, 2012, 08:32 |
Rep Power: 14 |
Yep, I must of missed that somehow in that brief 11,000 page read, but thanks for pointing it out for me.
batch mode, meshing |
[ICEM] How to generate this kind of mesh? | mingersai | ANSYS Meshing & Geometry | 51 | February 16, 2017 07:32 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
[snappyHexMesh] SnappyHexMesh not generate mesh first time | mavimo | OpenFOAM Meshing & Mesh Conversion | 4 | August 26, 2008 07:08 |
generate different mesh in CFX_MESH | Eric | CFX | 0 | June 23, 2006 09:09 |
