June 14, 2011, 09:49 |
Problem In Star CCM Plus
Ram
hi i'm a electrical student but as a part of my project i need to do analysis in star ccm plus on a airfoil
Joukowski foil wit 16%c camber and 6%c thickness 1. i had a made a 3d file in UG iges file but where to generate mesh file caal i mesh it in star ccm plus if so how? 2.at an angle of attack of 90 degrees and above which method i had to follow in star ccm plus ......................i.e at more flow separation which method is better for better results? 3. for my air foil i need to analyse angle of attack from 0-360 degrees for that can i get better results in star ccm plus or else i need to try some other software? Last edited by ramarya; June 14, 2011 at 10:36. |
July 10, 2011, 05:59 |
Rep Power: 21 |
1. The primary purpose of the documentation and tutorials is not to increase the installation size but help users. Have a look on it, it doesn't bite.
2.+3. At this high angles of attack, you will not get any good results with the standard turbulence models. You might perform a LES or DES, which is VERY computational expensive. 4. To get a solution which is not totally crap, I strongly recommend to get in touch with somebody with experience in a) aerodynamics b) CFD in general c) Using star-ccm+ |
Fluent Vs Star CCM | firda | Main CFD Forum | 3 | February 26, 2011 02:51 |
A genearl question on STAR CCM | nstar | STAR-CCM+ | 5 | June 24, 2009 09:39 |
star cd 4.06 parallel problem | whitemelon | Siemens | 3 | October 23, 2008 14:42 |
problem with export ccm from starccm+ | yan | Siemens | 0 | July 22, 2008 05:06 |
