Home > Forums > Mesh Generation & Pre-Processing Software > ANSA
Mesh analysis
Old   October 8, 2015, 08:07
Default Mesh analysis
jajo
jajo is on a distinguished road
Hello all
for my master thesis I like to compare different fan blades. My idea is to compare them by measuring the difference in the topology.
I need a tool in ANSA to measure the angle between the normal of each shell of my blade and the y-axis (for example). For better understanding I give you an example using a sphere:
When I look at a sphere the angle of the shell on top to y-axis should be around 90 degrees, for shells at the "aquator" the angle should be 0 degrees. The shells between should have angles form 90 to 0 degrees.
So far I hope you can follow me.
The result should be a distribution of shells (better areas) an there angle to the y-axis. For example 10 percent of the blade area have an angle of 5 degrees to the y-axis, 24 percent have an angle of 10 degrees an so on...
I hope everybody understand my problem and in the best case somebody is able to help me!
Thanks a lot
Best regards
Jake
jajo is offline   Reply With Quote
Old   October 27, 2015, 03:56
Vangelis Skaperdas
vangelis is on a distinguished road
Dear Jake
If you start ANSA in CFD layout
and go to the User Defined Functions button
you will find a UDF that does this exactly.
It is called
IsolateNormalVector
Hope this helps
Vangelis
vangelis is offline   Reply With Quote
Old   October 30, 2015, 09:08
jajo
Hi Vangelis,
that is exactely what I was looking for! Thank you very much!
Greetings
Old   November 1, 2015, 15:37
Vangelis Skaperdas
you are very welcome Jake!
Old   November 9, 2015, 04:28
Default Ansa projectig open holes
agassi is on a distinguished road
Hi vangelis,
I am new to ansa scripting and i would like to write a code for projecting open holes on a plate
my steps are as follows:
Shell mesh-Project-holes-select area by user-with diameter 6, node no 8 and zone1 3
Pls help me with writing the code
agassi is offline   Reply With Quote
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
Mesh Mignard FLUENT 2 March 22, 2000 05:12
