Home > Forums > Mesh Generation & Pre-Processing Software > ANSA
Double Elements-Ansa Volume Mesh
Old   January 16, 2012, 09:58
Default Double Elements-Ansa Volume Mesh
eishinsnsayshin is on a distinguished road
I've previously been using Tgrid for my volume mesh. I'm trying to start using Ansa now (where I've been doing my surface mesh). I'm new to volume meshing in Ansa and I'm running into a double elements error. I have a closed volume of FE's and I'm trying to "define" the volume. When I go to auto detect the volume using Volume>Define>Auto Detect, i get an error that says "Double elements Found. Cannot Continuee !!"
Ansa gives me the coordinates of the error and when I look there, I have nice looking surface mesh. There are no intersections, the skewness is low, orientation has been completed and is correct, and I've compressed all decks so there are no duplicate nodes. It's a really random location that Ansa is pointing to.
Is anyone familiar with this error and/or what a double element is? Thanks!
eishinsnsayshin is offline   Reply With Quote
Old   January 18, 2012, 04:12
Vangelis Skaperdas
vangelis is on a distinguished road
Hi there,
I would like to suggest that you use
D.UTIL>CHECK>DUPLICATE function from the bottom button menu.
A window will open. If ANSA has not detected the message will be in green. If it has detected, the message will be in orange. Expand the tree and select the listed entries with Show Only right click option.
Hope this helps
Best regards
Vangelis
vangelis is offline   Reply With Quote
Old   January 19, 2012, 07:34
Default cfd quality criteria
Ahad faiz
faizahad is on a distinguished road
Would u please send cfd quality criteria. I am using ansa 13.0
faizahad@hotmail.com
faizahad is offline   Reply With Quote
Old   January 19, 2012, 08:04
Vangelis Skaperdas
I would recommend that you upgrade to the latest ANSA v13.2.
Do you want the default quality criteria for CFD meshing? They are included in the software.
In the old 13.0 series you must start ANSA with the option
-gui cfd
In the newer versions, from v13.1
you can select from the launcher to start in CFD mode.
All the default settings will be loaded.
Hope this helps
Old   March 27, 2016, 06:05
Default double elements ansa volume mesh
alex
crusen mind is on a distinguished road
i am also not able auto detect my volume. i am getting a message of invalid volume detection.please check area close to some coordinates. Do u have any suggestions for this.
crusen mind is offline   Reply With Quote
Old   April 9, 2016, 09:25
Default intersection of pid
alex
hello vengalis
i generated layers for my wing when i try to generate volume, i am getting error of intersection of pid.
i already messaged the photos do u have any solution for that because last date for submission of my project is on 10 days
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
help: the volume mesh has highly skewed elements xiaofish FLUENT 3 September 18, 2007 09:51
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 08:06
