sami latreche
Rep Power: 14 ![]() |
I treat the phenomenon of natural convection double diffusion for a mixture of air-h2o and air-co2 in a square cavity
for a number of Ra = 10 ^ 5 then L (length caractristique) = 0.3 m the problem is: the convergence in Fluent ! the programe rest calculated ... then I think the problem is caused by the mesh I tried several meshes but same result pleas help me ************************************************** ******** Je traite le phénomène de la convection naturelle double diffusion pour un mélange air-h2o et air-co2 dans un cavité carré pour un nombre de Ra = 10^5 donc L (longeur caractristique) = 0.3 m le problème est : la convergence dans Fluent ! le programe reste calcule... alors Je pense que le problème est dû à le maillage J'ai essayé plusieurs maillages mais toujour meme résultat s.v.p aidez moi |
sami latreche
where is the answer
Maxime Perelli
Rep Power: 41 ![]() |
if you tried with several mesh and you still have same convergence issues, then I would say it is not a mesh problem.
What gives you an check mesh? I would try a simple convection problem on your mesh to see if your mesh is guilty
In memory of my friend Hervé: CFD engineer & freerider ![]() |
convergence fluent |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
Defect correction and convergence | ganesh | Main CFD Forum | 4 | June 30, 2006 14:20 |
