[GAMBIT] probleme of convergence
Old   May 4, 2012, 07:26
Exclamation probleme of convergence
sami latreche
sami34 is on a distinguished road
I treat the phenomenon of natural convection double diffusion for a mixture of air-h2o and air-co2 in a square cavity
for a number of Ra = 10 ^ 5 then L (length caractristique) = 0.3 m
the problem is:
the convergence in Fluent !
the programe rest calculated ...
then I think the problem is caused by the mesh
I tried several meshes but same result
pleas help me
Je traite le phénomène de la convection naturelle double diffusion pour un mélange air-h2o et air-co2 dans un cavité carré
pour un nombre de Ra = 10^5 donc L (longeur caractristique) = 0.3 m
le problème est :
la convergence dans Fluent !
le programe reste calcule...
alors Je pense que le problème est dû à le maillage
J'ai essayé plusieurs maillages mais toujour meme résultat
s.v.p aidez moi
sami34 is offline   Reply With Quote
Old   May 5, 2012, 07:20
Question ???
sami latreche
where is the answer
Old   May 7, 2012, 01:39
-mAx-'s Avatar
Maxime Perelli
if you tried with several mesh and you still have same convergence issues, then I would say it is not a mesh problem.
What gives you an check mesh?
I would try a simple convection problem on your mesh to see if your mesh is guilty
convergence fluent
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
