[ANSYS Meshing] long pipe mesh
Like Tree2Likes
  • 1 Post By jrunsten
Old   August 9, 2012, 02:58
Default long pipe mesh
far
trinitron is on a distinguished road
I have a long pipe which has narrow cross section.
I need a mesh that must be narrow at cross section and long in pipe length.
actually I need a cube mesh which has tall length and short width.
pls help me.
software: ANSYS 12
trinitron is offline   Reply With Quote
Old   August 13, 2012, 05:07
nitin bansal
nitinbansal184 is on a distinguished road
pls help me.
software: ANSYS 12
Can you more specific Need Files
nitinbansal184 is offline   Reply With Quote
Old   August 16, 2012, 00:48
far
what kind of files?
Old   August 16, 2012, 03:46
nitin bansal
.tin and prj files
Old   August 17, 2012, 03:09
far
.tin and prj files
let to explain with picture:
attached figures show my mesh and desired mesh.
if I use "my mesh", since the pipe is long (10 m) the number of mesh become too high. so I want the mesh like "desired mesh".
Can you help me about this?
I only have these files:
.cfx-.def-.out-.res
Old   August 17, 2012, 03:29
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
If you are meshing in workbench, and the tube is indeed just a tube, then you can select a face at a short end and insert "mapped face meshing"
See http://img401.imageshack.us/img401/7...0817092223.png
trinitron likes this.
jrunsten is offline   Reply With Quote
Old   August 17, 2012, 09:29
far
yes I work in workbench
thank you so much
I try mapped face meshing but the final mesh become like attached file(mesh.png). Not to "desired mesh".
Is there any way?
Old   August 17, 2012, 09:38
Josef Runsten
Increase the number of cells in radial direction. It's in the image i posted as well.
Old   August 17, 2012, 09:57
far
Your help is so useful.
but there is a problem which is still exist.
the elements on cross section are triangular, but I need rectangular mesh.
I attach the picture which shows triangular mesh on cross section.
If you look again to "desired mesh" picture in previous posts, you will see rectangular mesh Not triangular.
Old   August 17, 2012, 10:07
Josef Runsten
Ah I see. Then just add a method, choose sweep and change "Free mesh type" to All Quad.
See images :
http://i.imgur.com/sA2am.png
http://i.imgur.com/nlyKo.png
EDIT: Just occured to me that inflation of the boundary layer might be difficult if you want to keep it an hex mesh. For some reason its a hard thing for workbench meshing to do.. ICEM does this easily btw
Old   August 17, 2012, 10:52
far
See images :
I found the solution.
The mesh has been created normally.
thank Josef Runsten for your useful answers.
Old   August 20, 2012, 02:48
Josef Runsten
Couldnt quite let this go, since I knew you wouldn't be able to get a hex mesh with inflation layers using that method. A way that will work, and that isn't that complicated, is to split the cylinder in quarters in Design Modeler, then use a Multizone meshing method. The right click on the method and choose "Inflate this method". Choose the inner and outer wall on the four inflation items and you should be good to go. See http://i.imgur.com/qf2DB.png , or http://www12.zippyshare.com/v/74996362/file.html for the archived project (v14).
If anyone know a better way, other than ICEM, I would be interested in knowing.
Old   November 5, 2013, 03:39
Devid
David2013 is on a distinguished road
Hi Jrunsten,
I am having difficulties to successfully apply Multizone meshing with inflation to an object, which is half hollow cylinder and half hollow cone. I would appreciate if you share with me your archived examples.
Thank you.
David2013 is offline   Reply With Quote
Old   November 4, 2014, 16:45
SJ
ncwss_ncwss is on a distinguished road
The archived project is expired.
ncwss_ncwss is offline   Reply With Quote
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[blockMesh] 3d mesh for a pipe tsjb00 OpenFOAM Meshing & Mesh Conversion 2 January 30, 2009 04:40
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
