August 19, 2012, 13:30 |
Conformal mapping in hybrid mesh
Gomatam Sreekar
Rep Power: 14 |
I'm trying to create a hybrid meshing for some dynamic meshing. It's the simulation of a spheroid oscillating inside a fluid medium. To do this, I created a structured mesh around the spheroid and in the rest of the domain. Unstructured mesh is sandwiched between these two structured regions. How much I may try, I'm not able to create a conformal mesh at the interface. A little help would be greatly appreciated.
January 10, 2013, 15:18 |
Joris C.
Rep Power: 13 |
For 3D, the answer normally is Edit Mesh > Merge Node > Merge Meshes, as explained in the ICEM 11 tut man p458 (4.6.2 Hybrid tube)
For 2D (not this case, but if you're looking for it): see http://www.cfd-online.com/Forums/ans...ary-layer.html, especially the third post. Last edited by Coris; January 10, 2013 at 15:47. Reason: Added 2d case link for googlers |
conformal mapping, mesh, structured grid, unstructured grid |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[ICEM] Hybrid mesh | ringtail | ANSYS Meshing & Geometry | 13 | March 7, 2011 03:27 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
