August 29, 2012, 23:32 |
Hex meshing a cooler
clocter
Hi
I was wondering if you could produce a Hexa mesh for the entire cooler configuration and the blocking strategy involved? In the attached Fig meshing was done using WB - It had hex mesh in the outer domain and tet mesh around the pipes, the inner fluid was not modelled. (not satisfied..too many elements) It would be nice to have a hex mesh everywhere, can this be done by: - 2D blocking and sweeping around a profile for the pipe and doing a separate 3D blocking for the outer domain? - Full 3D blocking Top-Down approach? there are 44 pipes so it will be a massive task. If someone has done this before or have a better idea let me know. If you want to try it..use 10m pipe length, D of 6.625" (there is a thickness but can be ignored for now), curvature R=1.5D. Cheers |
[blockMesh] --> FOAM FATAL ERROR: Trying to specify a boundary face | A.A. | OpenFOAM Meshing & Mesh Conversion | 41 | June 26, 2020 07:06 |
[blockMesh] apparently the mesh doesn't want to be created in one direction | Maxime Thomas | OpenFOAM Meshing & Mesh Conversion | 1 | August 18, 2012 06:05 |
[blockMesh] BlockMesh number internal faces and boundary | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | December 13, 2011 05:36 |
[blockMesh] Blockmesh error - 2D scramjet | ishaninair | OpenFOAM Meshing & Mesh Conversion | 7 | March 18, 2011 00:14 |
CheckMeshbs errors | ivanyao | OpenFOAM Running, Solving & CFD | 2 | March 11, 2009 02:34 |
