[GAMBIT] 3d elbow
Old   September 4, 2012, 14:49
Default 3d elbow
MOHSEN HAMED
ENG.HVAC is on a distinguished road
i make my model in gambit is elbow with length 1 meter with more angles between inlet and outlet
each angle is a model i do
for 90 , 45, 120,30
it is a circular pipe
can any one help me in make this model
ENG.HVAC is offline   Reply With Quote
Old   September 5, 2012, 01:32
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
can you post a sketch?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   September 5, 2012, 07:33
MOHSEN HAMED
I want to create a 3d elbow geometries of angle 90, 60, 45 in gambit
seketch ihttp://www.mediafire.com/view/?4n7e16ig2m1b2qts attached
Old   September 5, 2012, 08:17
-mAx-'s Avatar
Maxime Perelli
it should help you:
http://www.cfd-online.com/Forums/ans...nd-angles.html
Old   September 5, 2012, 08:55
MOHSEN HAMED
Originally Posted by -max- View Post
i see it but i can't understand it
Old   September 5, 2012, 09:22
-mAx-'s Avatar
Maxime Perelli
create your section (surface), then sweep it along an edge (or edge-chain)
Old   September 5, 2012, 09:27
MOHSEN HAMED
can you start with me from first point please
point to point
Old   September 5, 2012, 09:31
-mAx-'s Avatar
Maxime Perelli
on the picture links you see what you need: your surface and the curve which will be used to sweep your section.
So first create you section
Then create the curves
Finally sweep surface with curve
[DesignModeler] Parametric elbow pipe thaenan ANSYS Meshing & Geometry 0 May 18, 2012 16:26
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
Appropriate model for turbulent, steady state pipe elbow flow milos OpenFOAM Running, Solving & CFD 4 July 9, 2009 02:24
rectangular elbow air duct problem tony FLUENT 2 August 20, 2006 19:07
problem of elbow pressure drop Tony FLUENT 2 July 17, 2006 17:03
