[ANSYS Meshing] Ansys Mesh
Like Tree1Likes
  • 1 Post By diamondx
Old   November 21, 2012, 11:46
Post Ansys Mesh
Swapnil
swapnil.chandratre is on a distinguished road
I am new to using Ansys, the trouble I am facing is not CFD specific but more general. While going through reference manual I read that mesh is usually considered unacceptable if the skewness is more than 0.95.
I am trying to see stress distribution on a C channel frame for a specific load, when I generate a mesh, I have a dense mesh with more than 42000 elements but skewness is 0.99.
I want to know how should one approach the problem to achieve a better mesh, or what parameters define the mesh to be acceptable or not.
swapnil.chandratre is offline   Reply With Quote
Old   November 26, 2012, 11:24
Swapnil
I can provide the Model image or data if that would help me get an answer.
Thanks !
Old   November 26, 2012, 11:28
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Here is some indidaction:
First of all these values are relative. There are many values which are not acceptable to Fluent but CFX. For example fluent is more tolerant of angle issue than the CFX. But Fluent does not like the pyramid shape and CFX does not mind it because of its internal working.
Keeping in view they have (meshing guys) have devised some metrices with factor of safety. Following are the most important quality metrics with thier range.
Angle : Must be greater than 18 deg (But some times Fluent sometimes can work as low as 9 deg)
Quality : Must be greater than 0.3. But quality of 0.2 or greater can be tried and if solver doesn't mind it than carry on.
Expansion rate: Change of cell volume with respect to neighbouring cells. Should be less than 10 (or 20 check the CFX of Fluent manual).
Skewness : (Fluent) Must be less than 0.8. Up to 0.95 is acceptable.
Aspect Ratio : Must be less than 100 for single precision solver and 1000 for double precision solver. But due to implementation of better algorithms, I have tested and found that AR up to 8000 is OK in boundary layer with no impact on the solution. Moreover it is the characteristics of boundary layer to have the smaller cell size in the normal direction where flow gradients are steep and have bigger cell size in stream wise direction as flow gradients are not sharp. This approach is not valid for the transition prediction where you requires ten time more mesh points in the vicinity of transition.
Important thing to remember:
If you are using Fluent then make the mesh which has orthogonal quality greater than 0.01. To ensure this you need to have the
1. Min quality greater than 0.3
2. Angle greater than 18
3. Smooth cell size change
For CFX, you need to ensure this in ICEM:
2. Min angle 18
By Far
Please do it...
Far likes this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
[ANSYS Meshing] Extruding 2D mesh to 3D mesh in ANSYS meshing Rachit ANSYS Meshing & Geometry 10 February 14, 2024 08:19
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Problem importing GAMBIT mesh to Ansys geometry David G. CFX 0 June 19, 2005 06:01
