November 27, 2012, 13:58 |
windturbine meshing
Rep Power: 14 |
Hello all,
I want to generate a mesh around a windturbine (tower+nacelle+rotor) I have worked with ICEM before to generate a mesh around an airfoil, cylinder,... but for this one I cannot make it Can anyone help me with it? I have the 3D-geometry, but when I import it into ICEM, it's just lines not a 3D geometry Thanks |
December 2, 2012, 00:25 |
Rep Power: 14 |
Im saying I have difficulty starting the process and you say "show pictures"
December 7, 2012, 06:58 |
#6 | |
Christoph
Rep Power: 18 |
which kind of 3D-geometry? step/iges or a is it a native cad file format?
it's often easier to import your geometry to desgin modeler first, then set up facet quality to 10 and export it as .agdb-file and import it in icem via workbenchreader or do you use the 14.5 version? icem is integrated in the workbench and things are much easier anyway....i can help you with the meshing. i've done it before (at least if you want to make a hex mesh). Quote:
[ANSYS Meshing] windturbine meshing | James Hetfield | ANSYS Meshing & Geometry | 7 | September 19, 2012 12:53 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
