[ICEM] how to reduce fine mesh in the centre of the hydrocyclone
Old   December 18, 2012, 00:14
Default how to reduce fine mesh in the centre of the hydrocyclone
veerukvb is on a distinguished road
hi,
I got one mesh problem in the hydro cyclone. I used tetra/ hexa mesh for the hydro cyclone. I got the finer mesh at the hydro cyclone walls on both sides but I could not able to make coarse mesh at the centre of the hydro cyclone where the air core will be formed. I want to connect/ associate two edges which are in adjacent to each other. I found one option in blocking i.e there is a link edge. I used that option even though I could not connect the two edges. I used another option i.e I merge two blocks of respective edges, in that case I joined the two edges at the top of the pipe but I could not find the joint between the two edges at the bottom of the pipe. could help me regarding this query.
veerukvb is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
inviscid 2d computation for M=0.3 flow past cylinder on fine mesh can not converge boubalos Main CFD Forum 3 March 20, 2011 04:26
New geometry in tutorial mixer2d unphysical solution for fine mesh christinasmuda OpenFOAM Running, Solving & CFD 6 January 16, 2009 07:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Mesh for 3 dim Geometry Phil FLUENT 9 July 12, 2000 04:39
