December 18, 2012, 10:18 |
Patterning Meshes
Steve
Rep Power: 13 |
Here is a picture of a set of bodies similar to what I am working with:
I was wondering if there was any way I could sweep this group of bodies quickly and if I could make their meshes identical without having to manually select each face/edge etc. manually. A: Figured out that I could select Multizone and select all the bodies using 1 of the faces as a source face to create identical meshes for each. Now I was wondering if there was any way to apply local settings (sizing, inflation etc.) to just one of the bodies and get it to apply to all of them? Last edited by huxxx088; December 18, 2012 at 11:18. |
December 19, 2012, 10:03 |
You can select the faces or edges you want to have the same properties and then just apply a single sizing to all of them. If 16 bodies are all you have it shouldn't be a problem.
I am curious about what you are simulating though. |
December 19, 2012, 10:29 |
#3 | |
Steve
Rep Power: 13 |
I exaggerated the geometry a lot, but I am modeling flow past thin walled baffles that change direction of flow (similar to inlet stators in turbines) |
[Technical] Automatic Mesh Refinement and Tetrahedral Meshes | philippose | OpenFOAM Meshing & Mesh Conversion | 8 | May 21, 2016 15:44 |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 07:06 |
[ICEM] how to create meshes of conformal nodes? | snailstb | ANSYS Meshing & Geometry | 2 | March 12, 2010 03:23 |
Merging Meshes | Matteo Giacobello. | FLUENT | 1 | February 16, 2000 09:22 |
Large 3D tetrahedral meshes | Aldo Bonfiglioli | Main CFD Forum | 4 | August 27, 1999 03:33 |
