[ICEM] ICEM Hexa_Airfoil with 2 sharp edges blocking? |
January 21, 2013, 11:09 |
Dear all,
I have been trying to mesh this airfoil in 2D after I did the youtube tutorial a couple of times. This blade is from an automotive cooling fan. Here's the profile Here it is after the O-grid and splits Then I thought I could just collapse both edges and blocks at the tips similar to the sharp trailing edge from the tutorial. I did and I'm getting this.. From the last picture, the 2 airfoil sides merge to one after I collapse both blocks at the edges.. Am I missing something or is what I am trying to do fundamentally wrong? I would appreciate some help.. Thanks, T |
January 21, 2013, 11:19 |
Bharat
Hello catthan,
-basically you can go for any profile around the airfoil and split it to generate the mesh what are your objectives? |
January 21, 2013, 11:24 |
You need quarter O-grid
See these threads: http://www.cfd-online.com/Forums/ans...ic-trough.html http://www.cfd-online.com/Forums/ans...w-winglet.html http://www.cfd-online.com/Forums/ans...ler-blade.html http://www.cfd-online.com/Forums/ans...tices-why.html http://www.youtube.com/watch?v=92vScop7b8Q Also try simple approach: http://www.cfd-online.com/Forums/ans...ned-plate.html |
January 21, 2013, 11:47 |
Ghazlani M. Ali
Rep Power: 29 |
your blocking is not good... look at thi thread :
http://www.cfd-online.com/Forums/ans...ic-trough.html |
January 21, 2013, 13:02 |
Thanks guys, quite a bit of reading there to do.
Will make a few attempts and post back. Thanks a lot! T |
January 24, 2013, 05:11 |
Ok guys, managed to mesh the airfoil successfully. The approach from the trough thread was the most applicable.
I looked at quarter o-grids and y-grids, however it wouldn't let me create them in 2D. Well, probably with a few smart splits I could have made a smth similar but anyway,, I'm sure I'll find this approach useful once I move on to 3D modelling. Thanks to all! Best, |
January 24, 2013, 05:26 |
#7 | |
However quarter ogrid can be used for 2d or 3d |
how to deal with sharp trailing edges in icem | joegi.geo | ANSYS Meshing & Geometry | 31 | March 5, 2018 19:57 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
