[ICEM] ICEM Hexa_Airfoil with 2 sharp edges blocking?
Like Tree1Likes
  • 1 Post By Catthan
Old   January 21, 2013, 11:09
Default ICEM Hexa_Airfoil with 2 sharp edges blocking?
Catthan is on a distinguished road
Dear all,
I have been trying to mesh this airfoil in 2D after I did the youtube tutorial a couple of times.
This blade is from an automotive cooling fan.
Here's the profile
Here it is after the O-grid and splits
Then I thought I could just collapse both edges and blocks at the tips similar to the sharp trailing edge from the tutorial.
I did and I'm getting this..
From the last picture, the 2 airfoil sides merge to one after I collapse both blocks at the edges..
Am I missing something or is what I am trying to do fundamentally wrong?
I would appreciate some help..
Thanks,
T
boobalan likes this.
Catthan is offline   Reply With Quote
Old   January 21, 2013, 11:19
Bharatt's Avatar
Bharat
Bharatt is on a distinguished road
Hello catthan,
-basically you can go for any profile around the airfoil and split it to generate the mesh
what are your objectives?
Bharatt is offline   Reply With Quote
Old   January 21, 2013, 11:24
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You need quarter O-grid
See these threads:
http://www.cfd-online.com/Forums/ans...ic-trough.html
http://www.cfd-online.com/Forums/ans...w-winglet.html
http://www.cfd-online.com/Forums/ans...ler-blade.html
http://www.cfd-online.com/Forums/ans...tices-why.html
http://www.youtube.com/watch?v=92vScop7b8Q
Also try simple approach:
http://www.cfd-online.com/Forums/ans...ned-plate.html
Far is offline   Reply With Quote
Old   January 21, 2013, 11:47
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
your blocking is not good... look at thi thread :
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 21, 2013, 13:02
Thanks guys, quite a bit of reading there to do.
Will make a few attempts and post back.
Thanks a lot!
T
Old   January 24, 2013, 05:11
Ok guys, managed to mesh the airfoil successfully. The approach from the trough thread was the most applicable.
I looked at quarter o-grids and y-grids, however it wouldn't let me create them in 2D.
Well, probably with a few smart splits I could have made a smth similar but anyway,,
I'm sure I'll find this approach useful once I move on to 3D modelling.
Thanks to all!
Best,
Old   January 24, 2013, 05:26
Far
Sijal
Thanks to all!
Best,
Y-grids is used on 3d blocking, but you can use in 2D if you are smart enough.
However quarter ogrid can be used for 2d or 3d
how to deal with sharp trailing edges in icem joegi.geo ANSYS Meshing & Geometry 31 March 5, 2018 19:57
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
