[ICEM] Unstructured Domain Split
Old   January 23, 2013, 14:13
Default Unstructured Domain Split
mememomo is on a distinguished road
I'm trying to create a plane which divides my box-shaped domain such that I can create a prism layer on either side of the plane. Two fluids will be modeled on either side in Fluent. In ICEM I just need the plane to grow the prisms and then I can delete the plane and its shell elements.
Whether I create the plane and its edges and points in DesignModeler or ICEM, I get a multiple edges error using build topology and cannot remedy the problem. If I mesh, I get single/multiple edge problems as well as holes along the exterior edges. I'm not sure if the edge problems will give Fluent trouble but I'm not understanding why holes are present.
Is there a more straightforward way to approach this problem? In case it makes a difference - I'm using unstructured elements.
Thanks in advance
mememomo is offline   Reply With Quote
Old   January 23, 2013, 14:23
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Some pics please...
Far is offline   Reply With Quote
Old   January 23, 2013, 14:31
Unfortunately I'm unable to attach images - ICEM is on a different system - but simply put, I have a box which, for meshing purposes only, I'd like to split in half such that I can create a prism region on either side of the split. I can delete the split surface or plane and its shells after meshing is complete.
When importing the geometry from DM into ICEM and running build topology, the edges (running along the exterior boundary of the domain) of this surface appear yellow.
My question is what would be a more straightforward method for splitting the domain for this purpose?
In lieu of images I hope this helps. Thanks for your reply Far.
Old   January 23, 2013, 16:13
Far
Sijal
see this...
With shared wall
https://dl.dropbox.com/u/68746918/shared%20wall.rar
w/o shared wall
https://dl.dropbox.com/u/68746918/shared%20wall2.rar
Old   January 24, 2013, 08:05
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Thanks in advance
First off, the plane should create a multiple edge. A multiple edge is just a "T" connection between the temporary middle plane and the walls. It is not an error, it is a possible problem. In your case, it is expected, so don't worry about it.
For the second problem, I am guessing that you tried to fix the first one and ended up deleting the elements around the edge (the multiple edge elements), so now you have single edge elements.
Try again, just ignore the multiple edge error and you will be fine. Not only could fluent have handled it without a problem, you will end up deleting those surface elements after your prisms are generated and not have it at all by the time you send your mesh to Fluent.
Best regards,
Simon
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   January 24, 2013, 08:08
Far
Sijal
Simon the approach I have used is relevant or not to the question asked? Because I am able to generate prisms on the both sides of intermediate wall and Fluent has no problem with it. I have two different fluids as well. May be I am missing the whole concept?
Old   January 24, 2013, 08:40
PSYMN's Avatar
Simon Pereira
Hey Far, you are fine...
Mememomo needed some help
I just didn't think your response addressed his concern about multiple and single edges.
Best regards,
Simon
Old   January 24, 2013, 08:45
Far
Sijal
Best regards,
Simon
@ Simon
I didn't mean that. I am new to tetra meshing. So trying to ask many questions. As your responses always helped me.
Old   January 24, 2013, 10:02
Thank you both -
Yes, Far - the image you gave is exactly what I'm looking for.
I was able to successfully mesh after creating the lines and plane and proceeding. Multiple edges aren't typical for the meshes I'm used to so thanks much for the info PSYMN.
icem, split, unstructured mesh
unstructured mesh phoenics user Phoenics 26 March 22, 2012 12:17
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Structured and Unstructured mesh Jingwei FLUENT 0 March 2, 2009 21:29
Public domain unstructured mesh generator Fabien Coppens Main CFD Forum 1 October 15, 1998 12:33
