[ANSYS Meshing] Having trouble meshing 3D model
Old   February 5, 2013, 12:07
Default Having trouble meshing 3D model
S1m0n1 is on a distinguished road
So I'm trying to mesh this 3D volume(http://imgur.com/1jtOjAO). It is a room with inlets and outlets. When I try to mesh, I do a mapped face mesh on all of the walls and the inlets/outlets. Then I to a face sizing on the walls and another face sizing on the inlets/outlets because I want them to be more refined than the walls. Now when I do this, The geometry changes from a check to a check with a slash through it and the mapped face meshing turnes into a blue "stop sign" as seen here (http://imgur.com/UABKagA).
When I try and move on to setup, I get a message saying the "Model Information is incompatible with incoming mesh."
Can someone help me with meshing this geometry because I am unsure what I am doing wrong? Also, if this mesh does work, does it meshing the whole volume or only the walls?
Thanks in advanced for any help.
S1m0n1 is offline   Reply With Quote
Old   February 7, 2013, 00:33
Mohammed
Mohd123 is on a distinguished road
This is possibly due to collusion of meshes. Try to delete any mesh setup and work your way out.
You can do Mapped face mesh for whole geometry and then refine mesh on walls and other areas as required.
Mohd123 is offline   Reply With Quote
Old   February 11, 2013, 20:54
So what I did was right click mesh-insert-method and then I sized 0.25. Next I did a mapped face mesh on all of the inlets and outlets and did a face size to 0.1. Now does the whole volume have a mesh size of 0.25 except for the inlets and outlets?
Also, if I would've done the same thing except did mapped face mesh instead of method, would this have done the whole volume? When I do this I have to click each wall so I'm not sure if it is only doing the walls or the whole volume.
I'm very inexperienced with meshing so any and all help is greatly appreciated. And if you don't mind pointing me in the right direction if possible that would be great.
Old   February 11, 2013, 21:07
And I'm not exactly sure how you work your way from inside out. Could you please explain that a little more?
Thanks
Old   February 12, 2013, 03:56
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
The volume mesh will be approximately 0.25, with a transition to 0.1 att he faces where you specified that sizing.
What do you mean with "Done the whole volume"
jrunsten is offline   Reply With Quote
Old   February 12, 2013, 11:35
When I do mapped face meshing, it asks me to select the sides. So I selected all of the sides and the ceiling and floor of the room. By doing this will it mesh the volume or just the surfaces?
Also, how do you mesh starting from in and working your way out? I am confused on how to do that.
Thanks for the replys.
Old   February 12, 2013, 23:29
Mohammed
I don't know what are the settings used for the mapped face meshing.
Try to delete the face sizings and do mapped face meshing only, if no errors occur. Add the face sizings making sure you use the correct factor values (a very small mesh size will normally result an error due to coarser mesh settings of mapped face).
Old   February 12, 2013, 23:36
Mohammed
Do a mapped face meshing for the whole volume using prefered mesh (hex, tri, ..).
Then resize the area needed to be refined with face sizing making sure its not too small. If you still can't manage to get a working mesh, try to divide the geometry into 4 parts.
It is a very simple geometry, I'm sure you will be able to do it.
Old   February 13, 2013, 02:48
Josef Runsten
The volume will be meshed if you press "Generate mesh". You can see the surface mesh by "preview surface mesh".
2D Meshing - No matter how thin my model is, it is still 2 elements thick RossFS ANSYS Meshing & Geometry 6 April 14, 2010 00:13
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
importing cylinder doesn't work & meshing trouble kfk STAR-CCM+ 1 January 7, 2010 03:34
Meshing difficulty in Gambit on a complex model Peter FLUENT 1 July 16, 2008 15:59
Vehicle CAD Model Meshing B Bru Siemens 5 June 8, 2007 17:30
