[ICEM] Negative Determinant
Old   February 20, 2013, 10:59
Default Negative Determinant
saisanthoshm88 is on a distinguished road
I've exported a mesh generated in Ansys meshing to the ICEM Input File(.prj) format.
Then I imported it into ICEMCFD. When I checked the determinant of the imported mesh in ICEMCFD, I found it to be a negative value.
Usually within workbench, I check the orthogonal quality, skewness and Minimum corner angle for the mesh and I found them good -
Orthogonal quality - 0.15
Skewness - 0.93
Minimum corner angle - 60 to 162 [deg.]
But the problem is with the negative determinant which I checked in ICEM after importing the mesh there.
Could some one please clarify this
Also is there a way to check the "equivolume skewness" in ICEMCFD I mean I'm not sure if the metric "equiangle skewness" of ICEM is in comparison with the skewness measure of Fluent.
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
