February 26, 2013, 11:54 |
Icem creates unwanted boundaries
Wolfram Jahn
Rep Power: 14 |
we use Icem 5.0 together with CFX 5.7 at my company. Every once in a while, without apparent pattern a few "artificial" boundaries appear when I import the mesh created in Icem into CFX Pre. Normally it's around a few elements within the body of the domain (image attached). The mesh in Icem looks perfectly fine, so I'm not sure whether this is a problem in Icem or in Pre. Any idea what could be the cause of this? Thanks! |
February 26, 2013, 19:00 |
Stuart Buckingham
Rep Power: 26 |
Hi Wolfram,
I have experienced this problem in the past when importing meshes with hanging nodes into CFX. Can you run a full diagnostic check on your mesh in ICEM before exporting? Stu |
February 27, 2013, 04:44 |
Wolfram Jahn
Rep Power: 14 |
Thanks Stuart, I will have a look at that today.
Far, I did not quite understand what you mean...sorry |
February 27, 2013, 12:21 |
Wolfram Jahn
Rep Power: 14 |
I think I have identified the problem: it arises when I produce a prism layer on the surfaces. The diagnostic from the mesh checker is "Uncovered faces".
When I fix the problem Icem creates a boundary around the elements, which is (apparently) exactly what CFX does when it gets a mesh with uncovered faces. I searched CFD Online forums for that error, but none of the proposed solutions worked. My idea would be to delete the affected elements, and somehow re-mesh that part of the volume. Problem is that I can't efficiently identify the elements in order to delete them. Any ideas? thanks |
[ICEM] Creating 3D mesh in ICEM with defined boundaries | martyn88 | ANSYS Meshing & Geometry | 4 | September 9, 2012 15:42 |
[ICEM] Meshing adjacent wall geometry and simple ICEM questions | everdimension | ANSYS Meshing & Geometry | 25 | June 20, 2012 04:25 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 06:23 |
Design Modeler to ICEM..... | Joe | CFX | 0 | January 24, 2008 03:39 |
Unwanted Wall Boundaries for 3D geometries | Cappy | FLUENT | 1 | July 27, 2006 01:39 |
