[ICEM] What causes negative determinants?
Old   February 26, 2013, 19:02
Default What causes negative determinants?
Colin Fiola
CDollarsign is on a distinguished road
What causes negative determinants when checking quality? It seems that I get negative determinants in my pre-mesh but then when I load from blocking I can fix them with the mesh check...
CDollarsign is offline   Reply With Quote
Old   February 26, 2013, 23:45
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
There are many reasons for negative determinant. Sometimes mesh is al-right but vectors are not and fix is simply fix the determinant.
But mostly this is due to penetrating elements into geometry or other blocks due to wrong association or misaligned blocked. The solution may be simple in some cases and in other cases you may have to redo the whole blocking in more innovative way. But keep on trying you will come to know what is causing problem and how to fix it. Sometimes the problem is due to edge mesh parameters.
Far is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
