[ICEM] Blocking strategy for a Multi Element Airfoil (ICEM) |
March 3, 2013, 12:38 |
Michael
Hey everyone,
for some days now I'm working on a blocking strategy for a multi-element airfoil in ICEM. My plan is to use a CHgrid. I've alredy meshed the single-element one porperly, but now I'm stuck. Unfortunately, I also could not find any tutorials or proper papers regarding multi-element airfoil meshing. My plan was to use one Ogrid Block in combination with the rearmost edge of the farfield for each element to create the Cgrid. But that does not work as intended. Now I was hoping, you guys could give some ideas and new thoughts on the topic. I'm not exactly explaining, how I was trying to mesh the geometry, so I eventually can get some new suggestions. Here a screenshot of the airfoil: http://imageshack.us/photo/my-images/534/airfoilm.jpg/ mix Last edited by mix; March 4, 2013 at 08:53. |
March 4, 2013, 08:53 |
Michael
After working a few more hours, I've achieved some results, but also an error.
I want so split a vertex, but ICEM only gives me the error "unusual neigborhood" (see the image attached). Does anybody know this error or how to solve it? Unfortunately, I could not find a solution for this. |
March 4, 2013, 10:27 |
Ghazlani M. Ali
Rep Power: 29 |
not many times, the split vertex has worked well for me. before using it, why don't you click on previous and jump where your merge those vertex. see why you needed to merged them... may be you didn't have to.
March 4, 2013, 10:44 |
Michael
Sorry for asking, but what exactly do you mean with "click on previous"? I haven't recognized this option yet. Or do you simply mean "undo"?
March 4, 2013, 10:49 |
Michael
Alright.
The Problem is, I saved several times in between, so I can't undo to that specific point. I probably will built up the model once again to work around the problem. |
March 4, 2013, 10:52 |
Ghazlani M. Ali
Rep Power: 29 |
when you save, icem does not replace your blocking, he keeps a backup of it. and keep just the last one. go to your folder you will find a lot of file with the extension blk0,blk1,bl2. those are backups of your blocking, just change the extension to blk and it will work again.
March 5, 2013, 04:32 |
Michael
I produced some results I want to shear.
I am aware, that there ist quite much skewness, especially at the slat between the airfoils. My blocking strategy was to first generate the cgrid for the main airfoil and afterwards the one for the flap, so I could fit one to the other. Feedback and tips for improving the mesh would be awesome. Mesh: http://imageshack.us/photo/my-images...turedmesh.jpg/ Slat: http://imageshack.us/photo/my-images/805/slat.jpg/ Blocking: http://imageshack.us/photo/my-images/708/blocking.jpg/ |
March 5, 2013, 07:47 |
Michael
Hey Far,
could you explain what you mean with "Quarter O-grid" a bit mor in detail? I'm just learning to use ICEM and I'm not familiar with all the options/possiblities. |
March 5, 2013, 07:57 |
#11 |
March 5, 2013, 08:02 |
#12 |
Michael
Thanks!
I will try this one on my model. If requested, I will post my results, as they are done. |
March 5, 2013, 12:46 |
#13 |
Michael
Far, I assume you mean something like this:
For now, just for the main airfoil and no mesh refinement ore anything like that is done. It will get interesting to adopt it for the flap. ----- First attempt with meshed flap: Last edited by mix; March 5, 2013 at 13:45. |
March 7, 2013, 04:46 |
#14 |
Michael
Sorry for another double post, but I do need some more help with this one.
As I can not find any proper sources for multi element airfoil hex meshing, some ideas, especially with the blocking of the flap, would be extremely helpful. My way until now was to first block the main element and after finishing this one, splitting blocks to generate a mesh for the flap. My problem now is, that in this way many small linked blocks appear which I don't know how to deal with properly. I don't thing merge blocks is the way to go, as I tried this option which did not result in a proper mesh. |
March 7, 2013, 10:23 |
#15 |
Ghazlani M. Ali
Rep Power: 29 |
did you see this thread : http://www.cfd-online.com/Forums/ans...ic-trough.html
it might help you... |
March 7, 2013, 11:33 |
#16 |
Michael
I did see this thread and I even built up the blocking for the main element as discribed there. The problem is the flap.
As I described, blocking it leads to several little linked blocks, as I blocked the main element first and then splitted the blocks to fit the flap. |
January 17, 2016, 13:41 |
3 Element Blocking in ICEM
#17 |
Hasan K.J.
Hello ALL,
Does anybody know or have any images of blocking for three element airfoils with slat and flap, - I would like to know how to efficiently block and mesh the slat region in ICEM. In the attached Image, can some one tell me how to solve the regions which is marked in RED Thanks for your time and Effort. Kind Regards, Hasan K.J
"Real knowledge is to know the extent of one's ignorance." - Confucius |
[ICEM] Having several dificulties with 3d airfoil meshing in ICEM CFD | Teja | ANSYS Meshing & Geometry | 14 | February 23, 2015 13:01 |
[ICEM] o grid blocking strategy? | icemaniac178 | ANSYS Meshing & Geometry | 14 | March 19, 2013 23:18 |
ICEM 5.1 to CFX Prism Element | ashish | CFX | 1 | April 6, 2005 18:32 |
multi element airfoil data | shadi memarpour | Main CFD Forum | 0 | June 20, 2004 04:33 |
Multi Element Airfoil | J.Dumas | Main CFD Forum | 2 | May 13, 2000 07:24 |
