March 5, 2013, 07:38 |
Gas separator blocking
Philipp
Rep Power: 26 |
Dear all,
I need to do the blocking for such a gas separator: geometry.jpg Blocking in y-direction seems to be pretty straight forward. But how would you do the blocking of in- / and outlet pipes? I am not sure how to connect standard pipe blocking with the actual separator blocks... I am happy about any ideas...
The skeleton ran out of shampoo in the shower. |
March 5, 2013, 08:07 |
Philipp
Rep Power: 26 |
Ok, I allways use the "workbench import" and import the geometry from the agdb file.
Anyway, here it is! ICM_tin.zip
March 5, 2013, 13:11 |
Philipp
Rep Power: 26 |
I already put round plates at top and bottom. I don't see any problem at these locations. What do you mean?
March 5, 2013, 14:08 |
Ghazlani M. Ali
Rep Power: 29 |
if you have too many elements in the up for example, they will be squeezed giving you then a bad quality. you have to add some quarter grid there. like in the picture below
Simplifying the geometry will not require you adding grid |
March 6, 2013, 03:50 |
Philipp
Rep Power: 26 |
March 6, 2013, 08:04 |
Philipp
Rep Power: 26 |
Hi again,
What do you think of this? 1st step -> large ogrid along the y-direction step1.jpg 2nd step -> cut edges of long block above and below the inlet step2.jpg 3rd step -> create ogrid at inlet pipe. The orange line / arrows show the way of the ogrid. step4.jpg
March 6, 2013, 08:11 |
Philipp
Rep Power: 26 |
No way, are you kidding?
So there is no way I can keep the o-grid of the inlet "inside", right? I have to let it leave on the backside in the same plane? I would prefer to have edges more or less parallel to the flow...
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
