[ICEM] Strategy for sharp corners
Old   March 22, 2013, 08:00
Default Strategy for sharp corners
Rolando Figueiredo
RPFigueiredo is on a distinguished road
Hello again,
I've managed to create a relatively satisfactory mesh, but I am struggling with its quality. As you can see in the image bellow, the model contains to problematic corners - very obtuse/acute angles.
You any of you recommend a different way of meshing this in order to improve the quality? Above 0.4 would be OK!
Thank you in advance!
RPFigueiredo is offline   Reply With Quote
Old   March 22, 2013, 08:30
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I am not able to see any image ... please attach again
Far is offline   Reply With Quote
Old   March 22, 2013, 09:00
Rolando Figueiredo
Sorry, here it is!
Old   March 22, 2013, 09:03
Far
Sijal
what is the problem?
Old   March 22, 2013, 09:10
Rolando Figueiredo
The element quality near the outlet and the periodic walls is very low due to the angles, I guess. Do you reckon there's a better way to mesh those corners, or is the low quality something I'll have to accept?
Old   March 22, 2013, 09:16
Far
Sijal
Actually I cannot visualize that area. Can you pin point that area and how much quality do you get?
Old   March 22, 2013, 09:27
Rolando Figueiredo
Here. Basically the geometry itself causes low orthogonality.
Old   March 22, 2013, 09:30
Far
Sijal
How much low? Like how much quality you have, min angle, dihedral angle, orthogonality, max volume change?
Plot with quality check menu and click on bars with low quality and post those pics
Old   March 22, 2013, 09:47
Rolando Figueiredo
Since I've just started dealing with CFD, I have been following the >0.4 Quality index (it's a CFX parameter). Not really sure how much would the max. volume change figure be, though!
I've also been informed to keep angles >18deg.
Thanks a lot for your time!
Old   March 22, 2013, 09:58
AB
BrolY will become famous soon enough
Quality > 0.3 is good enough.
But maybe you could improve the quality in this area. Can you share .tin and .blk files ?
BrolY is offline   Reply With Quote
Old   March 22, 2013, 10:10
Far
Sijal
I can see no problem in mesh. Every things seems ok. What is the maximum Y+?
Old   March 22, 2013, 10:16
Rolando Figueiredo
Not sure, I'll carry out a sensibility analysis probably resulting in a finner mesh (~1.5m elements, perhaps).
Thanks for the replies!
Old   March 22, 2013, 10:17
Rolando Figueiredo
I've tried doing it by moving the nodes - no success!
Is there another method you'd suggest? I was advised not to share the files, sorry! --'
Old   March 22, 2013, 10:25
Far
Sijal
In fact sharing them will give you good response from forum fellows. You can share privately.
Choice is yours.
Old   March 22, 2013, 10:45
Rolando Figueiredo
OK, If I would get some help with that, I could share the files for both stator and rotor (which looks a bit more messy...).
Can I share them here or should I get your e-mails through PM?
Old   March 22, 2013, 10:46
Far
Sijal
if it is confidential then through pm.
[ICEM] Mesh strategy large tank DoubleG ANSYS Meshing & Geometry 2 January 10, 2013 10:15
[ICEM] Blocking Strategy for Intersecting Tapered Cylinders scribby182 ANSYS Meshing & Geometry 2 December 17, 2012 10:02
How to find a good time scale strategy? StefanG CFX 19 June 8, 2012 08:41
Strategy for keeping track of files and folders? Dre CFX 1 October 30, 2008 13:00
Poinsot and Lele Characteristic BCS strategy for NS equations Ravikanth Avancha Main CFD Forum 1 March 15, 1999 19:51
